Old 09-26-2015, 11:04 PM   #1
Burnside Bob's Avatar
2009 25' FB Flying Cloud
1973 31' Sovereign
Mt Angel , Oregon
12V System Pre-wired for Accessories
In working on my 2009 FC 25FB I've found two pre-wired connection points for adding 12V accessories or for wiring option items my trailer doesn't have.
One is at the main panel where there is a pre-wired connection point on the purple 12V circuit. As this is adjacent to the under-bed storage compartment, I'm assuming the most common use is storage compartment lighting.
I found another between the shower and trailer wall, this one on the black circuit. I'm mystified about this one as the space between the shower stall and wall is tight and not accessible from either the interior or exterior.
What optional items would be wired in at these points? Are there other pre wired connection points I haven't found? Have you used these to wire in your own goodies? And if so, what goodies did you add?
Curiousity hasn't killed me yet. Good thing I'm not a cat!!
Best, Burnside
"To err is human, to air is devine."
Burnside Bob is offline   Reply With Quote
12v
12v and 110 - Wired together? KellySLC Electrical - Systems, Generators, Batteries & Solar 13 11-09-2010 08:49 PM
Airstreams Pre-wired for AC leeasu Furnaces, Heaters, Fireplaces & Air Conditioning 7 02-14-2010 04:09 PM
99 Suburban pre-wired for brake controller? RankAm Brakes & Brake Controllers 4 11-16-2009 05:29 PM
Pre-wired backup camera? TitusLivy Electrical - Systems, Generators, Batteries & Solar 9 05-01-2007 12:45 PM
Pre Wired for Heat 68 Safari soldiermedic Furnaces, Heaters, Fireplaces & Air Conditioning 3 11-21-2006 02:52 PM
