Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 09-23-2013, 08:36 AM   #1
Lexxy's Avatar
1973 23' Safari
Brevard , North Carolina
Images: 16
12v switch on old safari
1973 23' safari
Can't find a switch to turn off all the 12 v power
We ran down the battery and I read the whole manual...still getting used to this unit, I searched here but I still can't find a kill switch for the dc stuff.
Am I looking for something that doesn't exist? Where can I install one. I am getting 120 power to the unit today so I can recharge the battery.
Any help appreciated
Lexxy
After circumnavigating on 40' sailboat, cruising the USA in our '73 Safari, Tara!
Lexxy is offline   Reply With Quote
Old 09-23-2013, 08:39 AM   #2
damonbeals's Avatar
1998 31' Excella 1000
1979 23' Safari
Mooresville , Indiana
It does not exist, not on the older trailers. You have to disconnect the battery.
Damon
#4827
damonbeals is offline   Reply With Quote
Old 09-23-2013, 10:35 AM   #3
1974 Argosy 20
Kooskia , Idaho
The 73's had no 12 volt kill switch. You Could add one, like either a Perko switch or a simple heavy duty on/off switch, made for 12 volt power. Harbor Freight has them for about $8.
Old 09-23-2013, 10:41 AM   #4
1974 Argosy 20
Kooskia , Idaho
Harbor Freight item # 66789
Search results for: 'battery switch'
Old 09-23-2013, 11:29 AM   #5
AldeanFan's Avatar
1977 23' Safari
Niagara on the Lake , Ontario
Your battery should not run down unless you leave something turned on.
Interior lights, exterior lights, brakes, furnace fan, water pump and radio are the only things that use 12v power. The older fridges do not use 12v power.
1977 Safari Land Yacht
2005 Toyota Tundra SR5
2022 Toyota 4Runner SR5
AldeanFan is offline   Reply With Quote
Old 09-23-2013, 12:28 PM   #6
Lexxy's Avatar
1973 23' Safari
Images: 16
My fault...it was bright out an I left a light on. We had a switch on our boat so I think we will add this item in the rear closet to be sure. I tested the vent fan which is broken an I think I left it in the on position. I'm sure we all have to learn.
Thanks a bunch
Lexxy
12v
