Old 08-04-2003, 10:06 PM   #1
1978 31' Sovereign
Mesa , Arizona
12V power loss
Hi, I am the new owner of a 1978 airstream trialer. I have a 12V electrical question. I have noticed that when I turn on more than 3 or 4 lights, they start to dim. If I attempt to run the radio, it will not even power the speakers until I start turning lights off. Any ideas what this may be? The trailer has the original univolt converter And the lights are always dim. This occurs when I am plugged into 110VAC or 12VDC.
Slade Weaver
sladew is offline   Reply With Quote
Old 08-05-2003, 07:46 AM   #2
dtbw's Avatar
1999 34' Limited
2002 19' Bambi
Allen , Texas
First look for the obvious
This is a classic low voltage situation. This can be caused by a number of things. The first thing I would do is to disconnect the battery, unplug the A/S from 120V and then proceed to loosen the connections at the Univolt, wiggle them and then retighten. Do the same with the battery connections. Then do same at the 12V terminal block. If the dim lights still persist, I would have the battery checked as a shorted cell in the battery can pull the whole system down. Given that you indicated that the dim lights occur whether on 120 power or 12V power would seem to vindicate the Univolt. I really suspect a corroded connection somewhere.
david & bret
'02 Bambi LS
'99 34' Limited
Air Forums # 2159
Past President Heart of Texas Camping Unit
WBCCI # 7548
dtbw is offline   Reply With Quote
Old 08-05-2003, 04:47 PM   #3
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
univolt
check the condition of the fuse holders in the univolt.
they become unsprung and overheat. wd 40 and rotating the glass fuses is a temporary fix.
good luck
john
12v
12V System....Sudden Death! Help, please Alan and Mardel Electrical - Systems, Generators, Batteries & Solar 6 12-13-2003 11:04 AM
Newbie needs Classic 28' power management info Dave Jenkins Electrical - Systems, Generators, Batteries & Solar 3 07-24-2003 05:11 PM
No 12v Power wcdelorme Electrical - Systems, Generators, Batteries & Solar 13 05-11-2003 09:53 AM
B190 Coach power problem Luckydog Sprinter and B-van Forum 21 11-12-2002 12:59 PM
12V question uwe Electrical - Systems, Generators, Batteries & Solar 16 09-05-2002 01:14 PM
