Old 07-14-2011, 06:48 PM   #1
Alliesargosy's Avatar
1978 Argosy 27
Bay Area , California
Exclamation 12V Partial power - '76 Argosy 28
Hey Airstreamers! I need some help, I'm totally stumped.
I have partial 12V power. The front interior lights work, but the water pump does not (fuse is good). None of the other 12V items rearward are working. I've tested all fuses front & rear, Have good 12V power from the battery, new univolt. I even continuity tested the fuse holders, all seems to be well there.
Everything was working fine, then BAM! nothing. I'm on shore power, but I disconnected to test. The stereo works, but it's wired direct to the battery. I've got a solar unit, and it's showing the battery is at 13.4V.
It's gotta be some in-line fuse, or fusible link, or something somewhere?
HELP!!!
Thanks very much,
Allie
Remodeling our Argosy - read the blog here.
Alliesargosy is offline   Reply With Quote
Old 07-14-2011, 07:19 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Check your grounds. You may very well have one or more loose or corroded.
Old 07-14-2011, 07:20 PM   #3
1978 Argosy 27
Update - got the bath & two of three overhead lights working, but now the middle of the trailer is dark. Corrosion on the fuseblock - but arent the three overhead lights on the same circuit?
Old 07-14-2011, 07:58 PM   #4
1978 Argosy 27
okay - solved
Call of the Geek Squad - fixed. Intermittent faulty (not blown) fuse. Found it after I replaced all fuses - guess that needed to be done anyway...
12 volt, 12v, argosy, electrical
Power Loss & Pets Inside? Frank&Mike The Pet Forum 67 07-27-2013 08:57 AM
Interior power out in half of argosy. Cognito Electrical - Systems, Generators, Batteries & Solar 2 09-25-2011 11:49 AM
Solar Power for Battery Maintenance Tumajin Generators & Solar Power 10 08-12-2011 06:10 AM
Lost all 12V power Flynavy Electrical - Systems, Generators, Batteries & Solar 22 06-29-2011 04:49 AM
1973 Argosy / Airstream Camper - $4100 (Newark) 61Ambassador Airstreams on eBay 4 02-13-2011 11:11 AM
