Old 04-01-2004, 08:28 PM   #1
1983 34' Limited
Las Vegas , Nevada
Send a message via MSN to dmadam
12V circuits
Could anyone tell me where the 12V circuit breakers are? My two front vent fans stopped working. On one the lights dont work either. This all happened after I removed the wires from the AC switch which have since been reattached. I don't see why this should have any bearing and is probably just a coincidence but I still need to know where the fuses/breakers are. I have found the 110v's
This is on an '83 Limited.
Dave
Retirement happens when you get over the illusion of usefullness.
dmadam is offline   Reply With Quote
Old 04-01-2004, 08:36 PM   #2
jjonesnc's Avatar
Cary , North Carolina
Images: 8
Send a message via Yahoo to jjonesnc
Look under the front window
jjonesnc is offline   Reply With Quote
Old 04-01-2004, 08:39 PM   #3
1983 34' Limited
Las Vegas , Nevada
12v
I did and all I saw was the converter. I plan on taking the cover of that off tomorrow but from the outside it did not look to promising.
Thaks
Old 04-01-2004, 08:48 PM   #4
jjonesnc's Avatar
Images: 8
is there a carpeted panel under the front window? My 1980 Excella had a carpeted panel that snaps into place below the front window, remove the panel and the 12volt fuse panel should be right there.........
Old 04-01-2004, 08:53 PM   #5
jjonesnc's Avatar
Images: 8
12 volt fuse location
12 volt fuse location..................
Old 04-04-2004, 04:09 PM   #6
1993 29' Excella
Jonesboro , Louisiana
Mine is under the front window too. I think this is pretty much standard on later models. It is on the vertical wall below the window.
James Schmidt
29 ft Excello 1000
97 Expedition/Hensley Hitch/
McKesh mirrors
James Schmidt is offline   Reply With Quote
Old 04-07-2004, 09:52 AM   #7
1983 34' Limited
Las Vegas , Nevada
Thanks guys. I found breakers. I never thought to look behind the fabric panel.
David
Old 04-07-2004, 03:03 PM   #8
jjonesnc's Avatar
Images: 8
David, were any of the fuses blown?
12v
switch for 12v supply to refrigerator nickcrowhurst Refrigerators 11 02-09-2004 02:33 PM
12V System....Sudden Death! Help, please Alan and Mardel Electrical - Systems, Generators, Batteries & Solar 6 12-13-2003 11:04 AM
12v problem Chuck Electrical - Systems, Generators, Batteries & Solar 18 10-08-2003 11:15 AM
No 12v Power wcdelorme Electrical - Systems, Generators, Batteries & Solar 13 05-11-2003 09:53 AM
12V question uwe Electrical - Systems, Generators, Batteries & Solar 16 09-05-2002 01:14 PM
