Could anyone tell me where the 12V circuit breakers are? My two front vent fans stopped working. On one the lights dont work either. This all happened after I removed the wires from the AC switch which have since been reattached. I don't see why this should have any bearing and is probably just a coincidence but I still need to know where the fuses/breakers are. I have found the 110v's
This is on an '83 Limited.
Dave
Retirement happens when you get over the illusion of usefullness.
is there a carpeted panel under the front window? My 1980 Excella had a carpeted panel that snaps into place below the front window, remove the panel and the 12volt fuse panel should be right there.........
