Old 04-09-2006, 06:40 PM   #1
cameront120's Avatar
1972 25' Tradewind
120V help please.
In my 1972 Tradewind, there are two 120V receptacles forward - one between the galley and front couch and one opposite it, between the door and couch. When I'm hooked to 120V power these two outlets don't work (all others do), leading meto believe they are on the same circuit. My problem is that I can't find a blown fuse that might expalin the problem and don't have a clue how to look for the problem. Are there any electrical wizards out there who can explain to me in very simple terms how to troubleshoot the problem and hopefully fix it? I won't be offended ifyou all tell me to hire an electrician! Much thanks in advance!
Cheers!
North Vancouver, BC
Old 04-09-2006, 06:58 PM   #2
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
1. Remove power and then take the plates off the outlets and remove the outlets from the box, see if a wire is detached. Usually the outlets are wired in series and if a poor job was done it's possible the power connection has been lost at one of the outlets and the other one is further along the chain. You only have to pull the outlet out of the box far enough to ascertain whether any wires are loose.
2. I assume you have two circuit breakers in your electrical box. They can fail in a way that stops the voltage but doesn't trip the handle. Here's what I'd do first (I assume you've checked every other 120V electrical outlet and appliance, eg, air conditioner). Unplug from 120V. The cover on the electrical box will come off with two or four screws, not a big deal.
Once you get the cover off and can see what you are doing, you can measure the voltage at the wire coming out of the circuit breakers (plug back in to 120V and just don't be sticking your hands in the box). You actually don't need a voltmeter, just one of those neon power-checking bulbs with two leads.
or
You can remove the wires from the breakers (a small screw driver is required, not tiny, but small) and then remove the breakers and swap them, reattach the wires (actually, you remove the breakers, then take the wire out and switch--it's usually difficult to switch the wires when the breakers are installed) and put the breakers back in. Plug in to 120V and see if the outlets have power.
3. However, I doubt that it's a breaker--I think there would be more attached to that circuit.
4. If you can't track it down, I can look at the route of the wiring in my 1972 Overlander. Maybe there is a clue in some junction box between the electrical box and the outlets.
Old 04-09-2006, 07:32 PM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
On my 75 Trade Wind the wire diagram shows as follows:
Breaker 3 -> Refrigerator Outlet -> TV Outlet (above frig behind slide door) -> Street side forward outlet -> curb side forward outlet.
If yours is the same you should test each outlet and the problem is between the last working outlet and the first non working. It is most likely a wire out of the last working or a wire into the first non working.
*** Safety First ***
Remove shore power when you pull the outlets to inspect. Remember you might have a hot wire waiting to grab you!
Richard
Old 04-09-2006, 07:44 PM   #4
1972 25' Tradewind
Thank you Roger for taking the time to write that out. It's very clear...even for me! I really do appreciate it.
Thanks to you as well azflycaster for that. I'll use that sequence as a clue to see if it sheds any clues.
North Vancouver, BC
Old 04-09-2006, 09:05 PM   #5
lewster's Avatar
Naples, FL , Hood River, OR
You can also try a continuity test on the breakers. Turn off your main breaker and unplug from shore power. Remove the breaker from the panel. Put an ohm meter on the both breaker leads. If the breaker is in the on position, you should get an infinite ohm reading. Switch it off and you get nada, zip, zilch, nothing. If it tests like this, it is usually OK. If you get anything else, it is defective and must be replaced!
Old 04-11-2006, 07:43 PM   #6
1972 25' Tradewind
Hi all! I found the problem. A couple of wire became loose at the refrigerator outlet in the curbside panel. Azflycaster, the only difference with mine is that this location comes immediately after the outlet above the refrigerator, followed by the two forward interior outlets. So, everything now works in my 120v system. Now I have to sort out a few things in my 12v system at the control panel. Thanks again for your tips!
North Vancouver, BC
Old 04-11-2006, 07:57 PM   #7
2002 25' Safari
Dewey , Arizona
Images: 62
Great to hear that it is resolved! You have to wonder if they changed the wires route over the years or did the wire guy in 72 just have a "who cares" moment
Richard
Old 04-11-2006, 09:16 PM   #8
1972 25' Tradewind
I'd like to think he had a "who cares" moment...I like spontaneity!
North Vancouver, BC
Old 04-12-2006, 02:49 AM   #9
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Great ending and great step-by-step solutions to this issue. This is why I read all these posts. Everyone is very helpfull here.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 04-12-2006, 08:02 AM   #10
1972 25' Tradewind
Exactly! This is also why I print threads like this one and put them in my Airstream binder for future reference.
North Vancouver, BC
120V Plug Question for 55 Flying Cloud ?? cloud55 Electrical - Systems, Generators, Batteries & Solar 2 01-25-2006 02:28 PM
Advice for long term trailering Cheryl Full-Timing 49 07-29-2004 01:58 PM
wiring diagram 120v brunoffrance Electrical - Systems, Generators, Batteries & Solar 3 02-08-2003 01:41 AM
Battery Monitor Les Gilliam Electrical - Systems, Generators, Batteries & Solar 11 10-07-2002 08:13 AM
12v vs 120 jane babinski Electrical - Systems, Generators, Batteries & Solar 13 09-30-2002 09:23 AM
