Old 07-13-2016, 07:06 PM   #1
2013 25' FB Flying Cloud
Tulsa , Oklahoma
12 volt system not getting power
I have a 2013 Flying Cloud 27FB and after unplugging from shore power my 12 volt system doesn't get power.
Batteries are good.
Where is a fuse or breaker for the 12 volt system? I'm assuming under the bed.
Any help would be appreciated.
RC Photog is offline   Reply With Quote
Old 07-13-2016, 07:10 PM   #2
2012 23' Flying Cloud
2014 25' FB International
2014 27' FB International
Sugar Valley , Georgia
Were you using the store side of the battery switch?
Mike S. is offline   Reply With Quote
Old 07-14-2016, 07:45 AM   #3
Tulsa , Oklahoma
I tried both settings and the lights would just flash on but go off.
Old 07-14-2016, 07:50 AM   #4
Long Island , New York
Maybe the Use/Store switch is itself bad? Ours is like a small relay, not a hard physical on/off switch, so it could fail IMO.
At least you know you have power to the switch it appears. Further advice is beyond my knowledge, sorry.
Good luck!
Old 07-19-2016, 11:05 AM   #5
Wondering if you got this sorted out?
Peter
Old 07-19-2016, 12:15 PM   #6
Home of Vortex tuning
CDONA's Avatar
2013 27' FB Eddie Bauer
Spearfish , South Dakota
I had the store switch fail, I could turn it off all day long but wouldn't turn on.
Check the battery monitor to see what voltage you have available. Check the connections on the batteries, tight is good.
fuses are under the pantry at the breaker box
"Chip Tank" is in Hope Az.
CDONA is offline   Reply With Quote
Old 07-20-2016, 07:47 AM   #7
Tulsa , Oklahoma
Peter
I am going to replace the relay switch. I'm waiting for it to come in.
My best guess is this is the problem. I had power after switching it on and off several times but after I switched it to Store it would not come back on.
I'll let you know what happens.
Ralph
Old 07-20-2016, 02:07 PM   #8
CDONA's Avatar
There are 5? amp fuses on both sides of the solenoid that could prevent proper operation. I checked these too before I settled on my bad switch as the issue.
Old 07-30-2016, 11:17 AM   #9
Tulsa , Oklahoma
I checked the fuses and they are good. Replaced switch and it still only works intermittently.
What's next the solenoid?
Old 07-31-2016, 10:55 AM   #10
CDONA's Avatar
Look at all terminal leads for tightness. Intermittent operation is a bad connection. I could be internal on the solenoid, just bad one.
Old 09-05-2016, 03:12 PM   #11
Tulsa , Oklahoma
Replaced solenoid and it did the trick. All working now.
Old 09-05-2016, 03:14 PM   #12
Tulsa , Oklahoma
Peter
Replaced solenoid it all is working now!
12 volt
12 Volt Power Suddenly Not Working! vwchappy Electrical - Systems, Generators, Batteries & Solar 6 07-20-2016 07:09 PM
Power jack getting power. OffTheCouch Electrical - Systems, Generators, Batteries & Solar 11 01-01-2016 12:39 PM
Battery not powering 12-volt system worksology Batteries, Univolts, Converters & Inverters 0 04-21-2012 10:00 PM
Wiring Sequence to hook up 2 x 6 volt battery pack to your 12 volt trailer battery TobyJH Batteries, Univolts, Converters & Inverters 0 05-21-2004 01:04 AM
1961 - 12 volt or 6 volt? Marlboro Mafia Electrical - Systems, Generators, Batteries & Solar 4 04-19-2004 10:03 AM
