Did you check the fuse with ohm meter to see if you had continuity through the fuse. There should be some other fuses by the univolt or close to it. One of thoses could have blown when your light shorted out. Hope this helps.
Andrew Selking
WBCCI #6062
International 3rd Vice President
I would check the fuses from the univolt, should be around four. The older Univolts also have 2 screw in fuses on the unit itself. The univolt is easy to find when you are plugged into shore power, follow the hum!
Richard Wally Byam Airstream Club 7513
