Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 08-23-2011, 09:59 AM   #1
kmoore's Avatar
1993 34' Limited
Ten Mile (near Knoxville) , Tennessee
12 volt panel location
I have a 93' 25' Excella that I cannot find the 12 volt panel for. Looked high and low and now feeling pretty stupid. Converter is under the front goucho but cannot find the panel anywhere?
Two weekends ago I know I got my electric jack hot and in a bind and it must have blown a fuse/breaker. Cannot find anything in-line from the jack to where it dissapears into frame channel.
All other 12 volt systems are working and the positive from the harness to the jack is dead....no juice.
I guess I can re-wire direct to the batterie with an in-line fuse but hate to start butchering/rigging up like that if I do not have to.
Feeling stupid and know that fuse panel is hiding somewhere?
Any Ideas?
ID:	138489   Click image for larger version
kmoore is offline   Reply With Quote
Old 08-23-2011, 10:04 AM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 194
Greetings kmoore!
I am not certain when the location changed, but the 12-volt fuse panel was often hidden behind a panel on the Univolt. A small screw was removed and the cover could be opened to reveal the fuse panel. I know that both my '64 Overlander and '78 Minuet have this feature.
Good luck with your investigation!
Kevin
Kevin D. Allen
WBCCI (Lifetime Member)/VAC #7864
AIR #827
1964 Overlander International
Old 08-23-2011, 10:22 AM   #3
sander17's Avatar
1996 28' Excella
Okemos , Michigan
Images: 42
I doubt this will help, but on our 96 Excella, if you lowered the back of the goucho to make a bed, it exposed a small black door in the wall with the breakers inside.
Good luck.
Dave
Okemos, MI
T.V.:'05 Dodge Ram 2500 4x4 Quad Cab Cummins
AIR#2276
sander17 is offline   Reply With Quote
Old 08-23-2011, 11:33 AM   #4
tinman1's Avatar
2002 30' Classic
East Central , Alabama
We previously owned a '93, 25' Excella. The 12 volt panel was located behind the sleeper sofa on the front wall of the trailer.
Curt, Joan and "BonJovi"
tinman1 is offline   Reply With Quote
Old 08-24-2011, 08:32 PM   #5
kmoore's Avatar
1993 34' Limited
Thanks to all who replied................made me think. I have found it behind the snap on wall covering behind the gaucho. No you see now you don't.
Problem is still no fuses or breakers. I guess i will have to hot wire to the battery for the time being. Still learning the newer airstreams!
ID:	138606   Click image for larger version
Old 08-24-2011, 09:45 PM   #6
richinny's Avatar
2011 34' Classic
that's the 12v breaker panel. look for a white button on the sides that is popped out. a test light or meter will tell you if one blew. you might want to first test for power at the jack. you might have power and have a jack problem. it has switches that limit the travel.
some trailers have a circuit breaker in line near the jack.
Ricky
12 volt
Airstream Central Control Panel Jack.Ford Electrical - Systems, Generators, Batteries & Solar 21 08-10-2020 12:11 PM
Hybrid fuse panel pgr32e Batteries, Univolts, Converters & Inverters 1 07-14-2011 09:56 PM
AC and DC Panel Meter Additions to WFCO RonMansfield Batteries, Univolts, Converters & Inverters 1 06-28-2011 12:51 PM
Fuse panel for the moho chassis? WineStream General Motorhome Topics 7 06-01-2011 10:02 AM
Solar Panel Prices Dropping tbro Generators & Solar Power 11 03-30-2011 08:21 PM
