Old 06-03-2015, 04:38 PM   #1
gaylejoe's Avatar
2007 25' Safari FB SE
St. Hedwig , Texas
12 volt outlet not working
2 of 3 12 volt outlets not working in our 07 25' FB. Plugged a Fantastic fan into the outlet and it stopped working. The outlet is dead. If there is a fuse I sure can't find it. Appreciate and suggestions.
gaylejoe is offline   Reply With Quote
Old 06-04-2015, 08:20 AM   #2
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Pull the outlet and inspect the wiring. If you have a test light or multi-meter, use that to see if you have 12 volts coming to the outlet on the wires.
Chris
12 volt
TV outlet not working. ILOVESALLY Audio, Video & TV 5 09-28-2014 06:23 PM
Single Outlet Not Working gmp61 Electrical - Systems, Generators, Batteries & Solar 2 05-11-2012 08:08 PM
Outlet not working Mojave Electrical - Systems, Generators, Batteries & Solar 28 10-26-2011 02:29 AM
12 volt outlet not working M&M CAPECOD Electrical - Systems, Generators, Batteries & Solar 14 07-15-2005 10:25 AM
Help! 12 Volt Circuit Not Working on 97 Excella mello mike Electrical - Systems, Generators, Batteries & Solar 0 07-08-2005 02:16 PM
