Old 11-10-2006, 02:33 PM   #1
bluegrass's Avatar
2007 34' Classic S/O
Buffalo , New York
12 volt help for an electrical idiot
I hope this isn't too redundant but I am trying to replace a 12 volt plug (male end) on a coffee maker that was "melted" in the socket of my 2005 Safari. There was an electrical issue with the trailer that was resolved and a new 12 volt socket installed. I have no idea, however, what fuse (amps) I should use in the new appliance plug. I have tried to reach the manufacturer with no results. Anyone using a MarinePro (RoadPro) stainless coffeemaker that can tell me the fuse amps? Thanks. Joseph
bluegrass is offline   Reply With Quote
Old 11-10-2006, 02:47 PM   #2
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
I don't have that coffee pot but we do have a crock pot which has a 10 amp fuse in the socket.
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 11-10-2006, 03:51 PM   #3
Images: 59
Doesn't matter how many amps the coffee maker draws, what matters is the size of the wire going to the socket.
Can you pull the socket out enough to see the wire size?
Old 11-10-2006, 04:25 PM   #4
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
better yet... how many watts is the appliance rated for?
john
you call them ferrets, i call them weasels.
12 volt
Electrical changes 120 volt ac FrankR Electrical - Systems, Generators, Batteries & Solar 9 02-05-2019 06:38 PM
Fan-Tastic fan install Gordon Watt Roof Vents, Skylights & Fans 28 08-15-2011 11:41 AM
Loud range hood fan lbrodsky 2001 Safari 5 09-26-2003 06:08 AM
Larger Fan Blades in top Vent Sav'h Steve Roof Vents, Skylights & Fans 5 07-09-2003 05:35 PM
Exhaust Fan Cat Roof Vents, Skylights & Fans 1 10-04-2002 10:44 PM
