Old 10-13-2012, 07:28 PM   #15
Camoduk
Sammamish , Washington
Any idea where 12 volt fuse panel is on a 74-31 ft Sovereign? I have twins center and Lav in the rear. BTW I lost power to the refrig and the 2 forward driver side outlets. We changed the breakers [just because] hoping that was it but no change. Near the battery [rear passenger side]? Any ideas help...
camoduk is offline   Reply With Quote
Old 10-13-2012, 07:59 PM   #16
Ottawa , ON
Get on your knees on the floor in the closet between the bathtub and the curbside bed, it's on your right at the bottom.
Bring a flashlight, and open the door on the blue box there. You'll see the glass barrel fuses.
Old 10-13-2012, 08:04 PM   #17
Ottawa , ON
ps: the fusebox I just described is for the 12VDC circuits. The three breakers in the upper locker over the end of the other bed (the street-side one) are what controls the AC plugs. If they are still out after you flick all three to off then back on, you need to look upstream at the fusebox that feeds your trailer wherever you are parked.
Old 08-22-2013, 06:15 PM   #18
Karry's Avatar
1991 34' Limited
Mooresville , Indiana
Originally Posted by 2trackrr View Post
Yes I do have a new 1991 Diamond anniversary unit and will change my profile soon. Still have no Idea where the fuse panel is I will check the converter as soon as I take the front couch completely The only way to get to it.
2Trackrr
Did you ever find the fuse panel in the 91 unit? We spent a great deal of time today trying to find ours in the same unit but turned up empty handed. Except for finding some rotten floor and an old mouse nest 😦
Karry is offline   Reply With Quote
Old 08-23-2013, 06:47 AM   #19
2trackrr
1991 34' Limited
Waxahachie , Texas
The panel is on the left side of the coach as you face the front window behind the couch Also my unit has circuit breakers not fuses Hope this helps let me know
2Trackrr
2trackrr is offline   Reply With Quote
Old 08-23-2013, 07:49 AM   #20
Gainesville , Florida
I think the circuit breakers are for the 120 volt system. 12volt system is protected by fuses.?? Jim
Old 08-23-2013, 11:44 AM   #21
richinny's Avatar
2011 34' Classic
ai think excella/limited models have 12v breakers.
Ricky
Old 08-24-2013, 07:04 AM   #22
2trackrr
1991 34' Limited
Waxahachie , Texas
Fuses can be replaced Breakers just need time to reset Our unit has BREAKERS in it
Old 08-24-2013, 08:50 AM   #23
Oops, jim
Old 09-03-2013, 03:33 PM   #24
Karry's Avatar
1991 34' Limited
Wahoo we found it! Which lead to also needing to replace the battery and the inverter. Both were toasted but we are on our way in restoration !! Thanks for everyone's help.
12 volt
