Old 07-24-2007, 08:39 AM   #1
1986 27' Sovereign
Hilmar , California
12-volt Electrical to heater
I have a 1986 Sovereign and am having trouble with the heater. I am trying to access the circuit breakers for the 12-volt system. It appears that this is located behind the panel the displays the how full the tanks are etc. I don't see how this panel is accessed. My book indicates that circuit 3 goes to the heater so I am trying to start at the source. The last time I tried using the heater the fan didn't even come on. Any advice as to how to diagnosis the Suburban heater would be appreciated.
carron73 is offline   Reply With Quote
Old 07-24-2007, 09:52 AM   #2
Central , Mississippi
Start at the furnace, you may have a bad connection down there and I've had better luck accessing things in that area than at the control panel. Check the flat 4 way connector at the furnace to see if you have 12V and Ground.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 07-24-2007, 12:59 PM   #3
1986 27' Sovereign
Hilmar , California
Thanks, after I posted my query this morning I realized that the light over the sink / stove area is on the same circuit.
Old 08-01-2007, 07:23 AM   #4
Airboss's Avatar
1997 30' Limited
1972 23' Safari
1965 17' Caravel
Howell , Michigan
Send a message via AIM to Airboss Send a message via MSN to Airboss Send a message via Yahoo to Airboss
Well I have no 12 volts to my thermostat (Comfort Control) I am tracing the problem. I found the 3 amp fuse was blown inside Air Cond box. I have also checked breakers and the breaker at the furnace. Now its a matter of tracing the 12 volts...Trailer is a 97 30 ft Limited
"If your not living life on the edge... Your taking up too much room. WANTED, Single lady who loves and has a Airstream. Please send photo of Airstream and Tow Vehicle
Operation "SAVE RUDY" Strike Team (Charter Member) RALPH, KW8G..WBCCI # 4201 Metro Detroit & 4CU TAC # MI-007
Airboss is offline   Reply With Quote
Old 08-01-2007, 07:36 AM   #5
Hum, I never looked at the thermostat for voltage. My unit has 4 wires coming out of the heater, 12V, gnd and 2 that go to the thermostat for contact closure. I can tie the two thermostat wires together and the heater will come on.
Old 08-01-2007, 07:44 AM   #6
Airboss's Avatar
1997 30' Limited
1972 23' Safari
1965 17' Caravel
Howell , Michigan
2 of them are blue I think...What 2 do you tie together???
Old 08-01-2007, 08:28 AM   #7
I'll have to look when I get home, if my CRS doesn't kick in...
Old 08-01-2007, 08:40 AM   #8
Airboss's Avatar
1997 30' Limited
1972 23' Safari
1965 17' Caravel
Howell , Michigan
Im not the only one that has that??? Hmmmmmmmmmm Forgot what else I wanted to say..LOL..
Old 08-01-2007, 11:45 AM   #9
lewster's Avatar
Naples, FL , Hood River, OR
The 2 blue wires provde the furnace with the control voltage that tells it to turn on, providing that there is 12VDC to the pos and neg wires that feed the board, which in turn provides the voltage for the blower and the gas valve.
If you have voltage to the board, you can jump the 2 blue wires and the furnace should start and ignite after the purge cycle (approx. 30 seconds). You can do this test right at the furnace. If 12VDC is present at the board and nothing happens, you might have a bad board. You might have to remove it and have it tested. There are other diagnostics to do after that also.
Let us know what happens.
Old 08-01-2007, 03:05 PM   #10
Thanks Lewster, I probably was gonna forget to look that up tonight
Old 08-01-2007, 05:03 PM   #11
Airboss's Avatar
1997 30' Limited
1972 23' Safari
1965 17' Caravel
Howell , Michigan
What do you jump the blue wires to??
Old 08-01-2007, 10:52 PM   #12
lewster's Avatar
Each other.................
Old 08-01-2007, 11:26 PM   #13
Airboss's Avatar
1997 30' Limited
1972 23' Safari
1965 17' Caravel
Howell , Michigan
got ya..thanks...
12 volt
Hot water Heater DClark Water Heaters, Filters & Pumps 15 08-25-2017 02:35 AM
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 05:16 PM
Electrical changes 120 volt ac FrankR Electrical - Systems, Generators, Batteries & Solar 5 03-13-2005 06:20 PM
wiring - water heater Craig Electrical - Systems, Generators, Batteries & Solar 12 10-02-2002 05:03 AM
Water Heater shell frame BobbyW Water Heaters, Filters & Pumps 0 04-29-2002 10:21 AM
