Old 12-21-2009, 02:18 PM   #1
1973 31' Sovereign
12 volt distribution panel
Hi,
I'm looking for a new 12 volt panel--the univolt system is missing from my airstream, so I can't salvage the old one. Already bought a new converter.
My trailer is a 1973 31', but I have a feeling most will work.
Could throw you some cash or . . . trade?
Thanks!
seventythree is offline   Reply With Quote
Old 12-21-2009, 03:00 PM   #2
Originally Posted by seventythree View Post
Hi,
Thanks!
Are you looking for the one Airstream used, or an after market substitute?
The after market, will not have terminals for the ammeter, or for the power on light.
Old 12-21-2009, 03:48 PM   #3
1973 31' Sovereign
I think a (working) original would be best. I haven't done this particular project before, and I would KNOW that I had the right thing. It also seems like a lot of people are getting rid of broken or noisy univolts and might part with the panel.
That said, if there were an effective, inexpensive comparable product I'd use that. Searched forums and haven't found much. Especially on the inexpensive point.
Old 12-21-2009, 04:04 PM   #4
A new panel from Airstream, is expensive.
After market fuse panels are not compatible with the control panel up front.
Perhaps you can locate a panel from a discarded old Univolt.
Old 12-21-2009, 04:24 PM   #5
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I would go with a generic panel. There is no magic in the old one, only fuses and connections. You will not have a power on lug, but that is only supported from the univolt. The amp meter is no big deal, many don't work anyway.
Here is one that should work: 9 Position Fuse Block
Richard
Old 12-21-2009, 06:32 PM   #6
1973 31' Sovereign
Thanks. I've gone ahead and bought the one from Best Converter recommended here. Is there anything else I'm going to need for this project besides the converter and the fuse panel?
12 volt
12 volt distribution panel faceter548 Electrical - Systems, Generators, Batteries & Solar 4 08-21-2009 01:50 PM
Distribution panel upgrade nd48463 Batteries, Univolts, Converters & Inverters 6 05-23-2009 01:14 PM
Distribution Panel kennytheecat Electrical - Systems, Generators, Batteries & Solar 3 04-17-2009 05:29 PM
Sources for 12 volt distribution crispyboy Batteries, Univolts, Converters & Inverters 4 01-07-2008 01:50 PM
Low voltage distribution panel...Help k9s2go Electrical - Systems, Generators, Batteries & Solar 4 12-29-2006 01:54 PM
