Old 10-22-2019, 06:24 PM   #1
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
12 volt circuit breaker note
While dry camping this past weekend Missy plugged a 12v cigarette lighter to usb adapter into the bedroom lighter receptacle and the lights went out. On closer examination of the adapter I discovered the entire body was metal and there was only about 1/8” separation from the hot end to the negative side body. The hot end apparently engaged while part of it was still in contact with the ground side of the outlet.
I immediately checked all the 12 volt circuit breakers. No buttons were apparently popped up but I pressed them all anyway to be sure. No joy.
I assumed one of the splices I installed when I moved the electrical panel had failed and proceeded to check them all. That’s 4 hours in a cramped position I’ll never get back. I corrected one questionable splice but still no lights on that circuit.
In desparation I got out my meter only to discover that circuit 1 had no power. The button was not visibly raised. I pressed it with no result, so I got a toothpick and pressed it again. I heard a click and the lights came on. There was no percepible movement of the button and after being reset it looked just like it did tripped.
Moral of the story - there is no visual clue that a 12 volt breaker is tripped and you should use a small pointed object when resetting 12 volt breakers.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
12 volt
120 volt circuit breaker trips JIM CALDWELL General Repair Forum 2 06-15-2014 04:16 PM
Blown circuit breaker? bbrackman Electrical - Systems, Generators, Batteries & Solar 1 05-06-2005 07:42 AM
circuit breaker pops ... eubank Electrical - Systems, Generators, Batteries & Solar 3 01-30-2004 12:37 PM
Circuit Breaker Happycampers Electrical - Systems, Generators, Batteries & Solar 4 07-26-2003 07:51 PM
New circuit breaker strip FrankR Electrical - Systems, Generators, Batteries & Solar 0 03-27-2002 11:25 PM
