Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 06-05-2006, 05:01 PM   #1
Seekers
Profile:
12 Volt Breakway wire broke in the hitch channel
Help, does anyone know the routing of the 12V hot wire for the breakaway switch. Mine broke in the hitch channel. Are there any mid-way points that i can tap into.. Thanks
Seekers is offline   Reply With Quote
Old 06-05-2006, 07:40 PM   #2
CanoeStream
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
Hello Jim -- Can you feel it at all with your fingertips?
CanoeStream is online now   Reply With Quote
Old 06-05-2006, 09:49 PM   #3
Seekers
Profile:
12V wire
Bob, It looks like it broke around where the trailer starts. Not a chance! Its a good bad thing. It was grounding out and blowing a fuse everytime i moved it. I was in the process of installing a power jack. One strand of wire was all that was holding.
Old 06-05-2006, 10:36 PM   #4
CanoeStream
Images: 13
Take a look at Breakaway switch not working thread from last week. It gives some clues.
Old 06-06-2006, 06:04 AM   #5
AYRSTRM2
AYRSTRM2's Avatar
Profile:  1966 22' Safari
Armada , Michigan
Don't know your model, but there is probably a panel underneath the front of your coach held on with screws. In there will be the breakout of the wires from the pigtail and the switch. Find the breakaway wire to the brakes there where it connects to the main brake wire. On mine it is yellow. You can then run a new wire from there to the switch and twist on a new nut. Make sure the caulk your panel when you put it back on to seal it.
John
Visit my Camping Blog!
AYRSTRM2 is offline   Reply With Quote
Old 06-06-2006, 09:33 AM   #6
Seekers
Profile:
Bob, I appreciate the threads. I am sorting through them for best suitable advice. I forgot to mention. Iam working on a 1971 Caravel. Thanks
Hensley Arrow Hitch Les Hitches 10 02-28-2007 08:59 PM
1961 - 12 volt or 6 volt? Marlboro Mafia Electrical - Systems, Generators, Batteries & Solar 4 04-19-2004 09:03 AM
Hitch problem wyhjr Hitches 8 07-22-2002 05:29 PM
Hitch inspections 83Excella Hitches 3 07-09-2002 03:05 PM
Handy hitch step Pahaska Our Community 0 06-26-2002 05:44 PM
