Old 09-23-2017, 09:46 AM   #41
Half a Rivet Short
Carlisle , Pennsylvania
Originally Posted by prairieschooner View Post
Here is a quote from another site and a link;
http://www.power-talk.net/golf-cart-batteries.html
On the other side, heavy charge-discharge cycles for prolonged periods of time can distort and damage the thin, delicate plates. Furthermore, the positive plates will corrode much faster than a true deep cycle battery - which results in a very short lifespan.
6 volt golf cart batteries, with its thicker plates, are able to endure long periods of deep discharging and recharging with less effect on its life span.
there are many many other resources, just google them. Meanwhile the earth is not flat!
Hi
Thick plates vs thin plates has absolutely zero to do with 6V vs 12V. You don't suddenly get a thick plate on a 6V battery. Golf carts do not all use 6V batteries. Again, there are a range of cells (and even cell types) aimed at that market.
Again, what people are doing is looking at a Trojan T-105 and generalizing it to cover more than they should.
Old 09-23-2017, 12:53 PM   #42
2014 22' FB Sport
Mill Valley , California
We boondock a lot.
On our 22FB Sport, I took the location between the propane tanks and the trailer body to mount my Honda 2000 generator. Then, I put a couple Life Line military spec AGM 6 volt batteries in series under the back seat in the trailer, pretty much right over the axle for best weight distrubution. In the same space, I put a big inverter which powers coffee maker, toaster and 110 volt accessories without a problem.
220 amp hours
Andrew
awiegel is offline   Reply With Quote
Old 09-23-2017, 03:08 PM   #43
Half a Rivet Short
Originally Posted by awiegel View Post
We boondock a lot.
220 amp hours
Andrew
Hi
You could have put in an equally "mil spec" / equally AGM / equally well made Lifeline 12V battery and had 255 AH in a single package .... Or a pair of them for 510 AH.
If fitting things here and there is the issue, six 2V cells gives you even more flexibility. Six of them could get you 660 AH.
No magic about 6V ...
2 6 volt or one deep cycle 12 volt ErikFrolich Batteries, Univolts, Converters & Inverters 5 01-19-2013 01:27 PM
24 volt or 12 volt solar panels advantages?? purman Electrical - Systems, Generators, Batteries & Solar 13 09-06-2012 03:29 PM
6 volt vs 12 volt brakes? lwebb Brakes & Brake Controllers 17 07-14-2005 09:32 AM
Wiring Sequence to hook up 2 x 6 volt battery pack to your 12 volt trailer battery TobyJH Batteries, Univolts, Converters & Inverters 0 05-21-2004 01:04 AM
1961 - 12 volt or 6 volt? Marlboro Mafia Electrical - Systems, Generators, Batteries & Solar 4 04-19-2004 10:03 AM
