Old 04-22-2004, 07:20 PM   #1
R&SZinser's Avatar
Yorktown , Virginia
12 Fuse's?
I've got a 1985 Sovereign 25' and am not sure if there are fuses for the 12V system. I've found the 12v distribution box. Is there a 12v fuse panel somewhere else?
Name:	1- (2) (Small).JPG
R&SZinser is offline   Reply With Quote
Old 04-22-2004, 07:57 PM   #2
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
That is it. There are no fuses. There may be one in line to the radio and the water pump, but they are within 6 inches of the devices.
Those are auto reset circuit breakers. They will serve the same purpose as a fuse, but you will curse the engineers if you ever need to replace one. The breakers are riveted in throught the back.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 04-23-2004, 05:37 AM   #3
R&SZinser's Avatar
Yorktown , Virginia
Thanks Brett! Now I don't have to continue crawling thru the service manual wondering if I've missed something...
replacing glass fuses with blades maznblu Electrical - Systems, Generators, Batteries & Solar 4 08-06-2003 12:34 AM
Fuse size? working Electrical - Systems, Generators, Batteries & Solar 5 05-08-2003 11:11 PM
12 volt fuses jim clydesdale Electrical - Systems, Generators, Batteries & Solar 2 03-18-2003 06:47 PM
Electrical problems... DbackFan Electrical - Systems, Generators, Batteries & Solar 9 02-13-2003 11:44 PM
Should I replace the fuse box with a breaker panel? Andy R Electrical - Systems, Generators, Batteries & Solar 2 09-13-2002 11:21 PM
