04-01-2007, 12:36 AM
1958 22' Flying Cloud
Saint Helena
110v Power Cord Configuration
It's time to try to hook up the electrical and find that I can't locate a cord that matches the plug on the side of the rig. It has three identical spades in a triangle (not touching the corners). I saw something similar at Camping World, but it has the standard U shaped ground terminal. How do I make a connection? I'm envisioning that there is some pig-tail out there that can make the transition from 1958 to today. Any ideas for a source.
04-01-2007, 07:23 AM
2013 31' Classic
Crossville
, Tennessee
Maybe you could start here and then chase it down?
VintageAirstream - Restoration Resources
steelbird312 WBCCI #6673 jerry Hodge
2013 31" Classic limited
Have no intention of arriving at the grave safely, but rather to skid in sideways, chocolate in one hand, throttle in the other, totally worn out and screaming
"WOO HOO, WHAT A RIDE!"
04-01-2007, 08:31 AM
Moderator Emeritus
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna
Greetings bevman!
The power supply inlet was made by Theo Bargman Company and has been obsolete for a number of years (at least a decade). On ocassion, one will turn up in an RV dealer's old stock (or even less frequently in the old stock of an electrical supply house), but it is not a frequent occurrence. One alternative is to install a similar (but larger) power inlet designed for marine use -- these inlets are not inexpensive, but function quite similarly to the original.
Good luck with your search!
Kevin
Kevin D. Allen
WBCCI (Lifetime Member)/VAC #7864
AIR #827
1964 Overlander International
04-01-2007, 09:05 AM
Saint Helena
I thought of changing out the "port", but my initial investigations don't turn up anything that would fit, look appropriate, or enhance operation.
04-01-2007, 10:35 AM
Moderator Emeritus
1964 26' Overlander
Anna
Greetings bevman!
I don't know whether you have run across Hubbell-Marine fittings, but they make the stainless steel fitting for the coach with a heavy duty bright yellow power supply cable. It can be found on page 7 of the catalog in the link below. It is #HBL303SS.
http://www.hubbell-marine.com/pdf%20files/msection1.pdf
I know of several in the VAC who have been searching for either the power supply cable end to match up to the Theo Bargman connector or replacement Theo Bargman connectors without any luck after two or more years searching -- I also know of two who found these ellusive parts in the new old stock parts of long-time RV dealers about two years ago.
Good luck in resolving your dilemma!
Kevin
Kevin D. Allen
AIR #827
12-08-2007, 12:12 AM
1961 24' Tradewind
Cupertino
Hubbell plug
Happy Holidays, Overlander64
I am trying to find a replacement for the original Hubbell plug on my 61 Tradewind. The plug does not seat very well anymore.
The old plug is a 50A 250V DC, 50A 600V AC Hubbell twist lock, cover ground.
It looks like the mounting on the old plug is in electrical contact with skin of the trailer but the HBL303SS is insulated from its mounting surface.
Have you ever run into this being a problem?
Thank you for the help.
David
01-14-2008, 09:24 AM
1959 18' "Footer"
newport Coast
Same Problem
Well, I am sad to say that we too are in the same situation . We can not locate a power cord for the 1959 18' Globe Trotter.
Can you let me know if you had any luck, or if you ended up replacing the connection? If so, what did you do?
We are going on our first rally in Feb. (Notreallyrallyrally) and we really want to get power in the "Welshly" as we call it.
Thanks for any help you can give, or anyone else with a sure fire fix.
01-14-2008, 09:50 AM
1971 27' Overlander
Central
, Ohio
Can Someone post a photo please
What are you trying to hook to? Maybe an older RV dealer around might still have an adaptor - be happy to look locally.
01-14-2008, 11:49 AM
1959 18' "Footer"
newport Coast
Power plug
Thanks for the help. We are presently searching old RV dealers. I will try and post pictures as soon as I have the time to figure out how to.
Thanks again, let me know if you run into one of these old dino plugs.
KC
04-11-2011, 12:27 PM
1961 24' Tradewind
Cupertino
Old Hubbell replacement
After doing a lot of home work I found that there is a replacement plug out there. It is a Hubbell, HBL7968. I had to get it from a commercial electrical equiment store and it cost over $100.00?
It is a non-NEMA plug so the standard plug in use today will not work. The wiring configuration is strange also. I connected the wires up the same as from the old plug.
The HBL7968 plug has a spring loaded cover to keep the weather out. There is another model without the cover that is cheaper.
04-11-2011, 01:25 PM
1961 24' Tradewind
Cupertino
Let me add some more details on the Hubbell replacement.
The male plug is HBL7765C and the female, which goes into the skin of the RV, is HBL7968. See page B59 of the Hubbell catalog under Twist-lock devices.
These plugs are not to current NEMA standards and will not work with what is sold today. Be careful of the wiring configuration because standards or previous owners may have changed things.
04-11-2011, 01:33 PM
Wise Elder
2010 30' Classic
South of the river
The correct 50A connector is the Marinco 6373EL and similar and mating components. These are available as part of the Marinco "Park Power" product line through RV dealers, retailers like Amazon and vintage Trailer Supply, and electrical supply houses.
The Hubbell part you list is intended for three-phase operation and while it will work on RVs it will not interconnect with any commercially available shore power cables.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Stand up power cord
Happycampers |
Electrical - Systems, Generators, Batteries & Solar |
0 |
04-18-2004 07:03 AM |
External Power Cord Replacement
jstaad |
3 |
01-23-2003 06:16 AM |
power boosters
John |
Our Community |
18 |
11-19-2002 03:54 PM |
B190 Coach power problem
Luckydog |
Sprinter and B-van Forum |
21 |
11-12-2002 12:59 PM |
Phone cord
Joan D'Andrea |
Cabinets, Counter Tops & Furnishings |
0 |
11-02-2002 10:38 AM |
