Old 06-12-2017, 03:41 PM   #1
MarkJUrban's Avatar
2016 30' International
Richfield , Ohio
1 Micro Air 2 Air Conditioners | Dilemma
I own a 2016 international 30ft. 2 airconditioners. This model has built in ducting. I purchased 1 EasyStart from Micro Air, as I only travel with 1 honda 2000.
Which air conditioner should I install it on? Is one of the units more efficient then the other because of its placement?
Thanks!
MarkJUrban is offline   Reply With Quote
Old 06-12-2017, 05:53 PM   #2
2015 28' Flying Cloud
Newtown , Pennsylvania
Install the EasyStart on the AC you use the most. Or, get another EasyStart.
Bruce
50 amp, Awning package
2015 Ram 2500 6.7 TD, Blue Ox 1000 lb.
4 Lifeline AGM, Trimetric 2020
PD9160 converter, Prosine 1800 inverter
2x eu2000i Propane
AstroBruce is offline   Reply With Quote
Old 06-12-2017, 06:48 PM   #3
Half a Rivet Short
Carlisle , Pennsylvania
Hi
After a bit of experimentation (we are on a 30A circuit so we can't run both units).
When you are awake, it's hot and you need the AC. At night it cools down and you need it less. (I have empirical data, the sun set here a little while ago.). The "kitchen" AC is bigger than the "bedroom" one (at least I think it is). We tried running one for a while and then running the other for a while. During the day, the "kitchen" unit was voted best. Right now if I shut off the vents here, the air goes pretty well into the sleeping area. Yes, that's on a Classic and not an International. 30' is still 30' ...
Have Fun !!
uncle_bob is online now   Reply With Quote
Old 06-12-2017, 06:57 PM   #4
The Colonel's Avatar
2017 25' Flying Cloud
Navarre , Florida
If the ACs are two different BTU sizes, i.e. 13.5 and 15K then I'd put it on the larger unit.
The Colonel and Southern Belle
The Colonel is offline   Reply With Quote
Old 06-12-2017, 07:06 PM   #5
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
BINGO. Put it on the 15k unit which should be the front unit
Old 06-12-2017, 08:05 PM   #6
jayseejay's Avatar
2015 27' FB Eddie Bauer
2011 25' FB Flying Cloud
Fernandina Beach , Florida
Consider installing a second EasyStart, which should permit you to run both ACs at campgrounds with only 30A service; it works for us, with 15,000 and 13,600 Dometic Penguin II units, which is probably what you have. Joe
jayseejay is offline   Reply With Quote
Old 06-13-2017, 06:59 AM   #7
MarkJUrban's Avatar
Richfield , Ohio
Thanks everyone! The unit in the front is bigger. I had no idea.
Great point on installing on both, especially for those 30amp sites.
Old 06-13-2017, 11:50 AM   #8
dames7's Avatar
2015 25' Flying Cloud
GILBERT , Arizona
Who can help me install the Easy Start on my 25ft, due to back problems its a little hard to get on top to do the install.
David & Nancy Ames
WBCCI # 9403 -- AIR # 95597
2015 FC 25' RB
2013 Chevy Tahoe LTZ
dames7 is offline   Reply With Quote
Old 06-13-2017, 12:21 PM   #9
Electronic Controls OEM
Micro-Air's Avatar
Allentown , New Jersey
Hi Dames. Presently in the Phoenix area, we have no installation dealers that we have worked with. The closest one is in Page, AZ, a long way from you. If you want to recruit your local RV servicing or Airstream dealer to do the installation for you, Micro-Air and I will be happy to provide them the necessary guidance.
Technical Support
Micro-Air, Inc.
Micro-Air is offline   Reply With Quote
Old 06-13-2017, 12:24 PM   #10
dames7's Avatar
GILBERT , Arizona
Can you give me their info. I going that way in two weeks
David & Nancy Ames
2015 FC 25' RB
Old 06-13-2017, 12:57 PM   #11
Mollysdad's Avatar
Someone mentioned on another thread to run one AC (I'd do the 13,500 unit), and then just the fan off the other unit. The fan helps circulate the cold air.
Old 06-14-2017, 07:30 PM   #12
Troutboy's Avatar
2017 23' Flying Cloud
Parker , Colorado
David, come to Colorado and I would be happy to install it for you! No cost....
Troutboy
Troutboy is offline   Reply With Quote
Old 06-14-2017, 07:40 PM   #13
dames7's Avatar
GILBERT , Arizona
Thanks, Micro Air found me a guy that installs these in Page, AZ and I was going there at the end of June anyway.
He has lots of these and only going to charge $50 and told me it will take about one hour.
After that we are going somewhere in CO., then to the International RALLY in JULY.
I have had back problems and just can't due the ladder thing, thanks anyway.
David & Nancy Ames
2015 FC 25' RB
Old 06-15-2017, 09:23 AM   #14
Half a Rivet Short
Hi
In this day and age, $50 is a *very* fair price to get something like that done.
Old 06-22-2017, 12:37 PM   #15
MarkJUrban's Avatar
Richfield , Ohio
Update: install went smoothly. The step by step instructions on the Micro Air site made the job simple. I filled the Honda generator up (1 gallon I believe). The air ran for three hours before running out of gas.
Old 06-22-2017, 03:09 PM   #16
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Well done! I'll be order 2 units for the new 30'.....
wulfraat is offline   Reply With Quote
Old 06-22-2017, 06:18 PM   #17
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
I have installed Easy Air's on both the front and rear A/C's. After putting the first one on the front unit, it was an easy call to add the second. Since I have the Magnum MSH-30 inverter and 4 6V AGM's, I decided to try out the A/C on the batteries only. (I had done this routinely at rest stops when it was hot in the trailer and I didn't want to start the generator.) Not unsurprisingly, the Easy Start seemed to get the A/C into cool mode fairly quickly. Motor starts right up, and a bit later the compressor kicked in. I ran it on the batteries for about 45 minutes and still had plenty of juice left. I am Easy Start advocate. Thanks for a great engineering job, Matteo.
_________________
"SilverLeaf II" 2015 30' Classic
2019 RAM 2500 Limited 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 10-30-2018, 02:43 PM   #18
2019 27' Globetrotter
Salem , Oregon
Since the last comments are over a year old might I ask the same question. Ready to order new 27'. Since I live in Oregon one air would do but if there are dis-advantages to two, I think I would be better off down the road for re-sale, travel to Arizona etc.
Thoughts from others. Thanks
Dave
NoResults is offline   Reply With Quote
Armstrong RV Air conditioners pap Furnaces, Heaters, Fireplaces & Air Conditioning 90 07-06-2018 07:20 PM
ARA Dash Air Conditioners kmpro Classic Motorhomes 32 10-07-2017 09:53 AM
Advent Air Conditioners... Kevo Furnaces, Heaters, Fireplaces & Air Conditioning 5 05-17-2011 06:51 PM
HOT Topic for the summer-Air conditioners-Best/worst? thenewkid64 Furnaces, Heaters, Fireplaces & Air Conditioning 4 07-03-2002 04:55 AM
Air Conditioners JAG Furnaces, Heaters, Fireplaces & Air Conditioning 2 03-19-2002 01:25 PM
