Old 07-26-2016, 03:17 PM   #1
1972 27' Overlander
Norman , Oklahoma
1/2 120V outlets don't have power?
After 3-4 years of setting I can not get the front half of the outlets in my 1970 27'twin bed LY to work. Wire tracer signal is detected at all of the outlets but I can not find the junction box to check the connections for corrosion. All inside outlets (except the bathroom) are on one circuit and the two outlets in the bedroom work. Univolt, bath and patio outlets all on one circuit. AC on 3rd circuit. Can not trace wire runs because of the aluminum interior skin.
I have not checked continuity between the front outlets and the bedroom but the tracer signal is detectable at all outlets.
Anyone have an idea?
rokjok is offline   Reply With Quote
Old 07-26-2016, 03:34 PM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
It is rare for the problem to be in the walls.
I would start, with power disconnected, by removing each outlet from the wall, check for loose screws, loose wire nuts, or any dodgy connections. Failing that you can check continuity by connecting white and black together at one end of each wiring segment and using a meter on the other end until you find the problem.
Old 07-26-2016, 04:19 PM   #3
TheGreatleys's Avatar
1974 27' Overlander
Baltimore , Maryland
I agree with Jammer, very unlikely for your problem to be inside a wall. Your outlets are daisy-chained together with wires accessible inside the box behind the receptacles. I have my money on your problem being located inside one of the working bedroom outlets that feeds the rest, or possibly the closest nonworking outlet. Shut off the power, remove the receptacle to look for the problem, and if you're like me go ahead and replace it with a new one while you're in there. Outlets are cheap....
TheGreatleys is offline   Reply With Quote
Replacing interior 120v Outlets Soyboy Electrical - Systems, Generators, Batteries & Solar 5 11-02-2017 05:35 PM
Outlets don't work...after battery changed out Livinfree Electrical - Systems, Generators, Batteries & Solar 8 05-03-2016 12:15 PM
Leviton USB 120V Outlets KJRitchie 2006 - 2010 Classic (all lengths) 14 03-31-2016 08:03 PM
Half of the outlets have no power VeggieBullet Electrical - Systems, Generators, Batteries & Solar 23 01-22-2012 08:08 PM
Replacement 120v outlets or Home Depot? dalefox Electrical - Systems, Generators, Batteries & Solar 2 06-09-2009 05:33 PM
