Thanks for the welcome Kenneth!
I'm working in the front half of the trailer and will post pics once I get it a bit more finished. As I said everything was just white from one end to the other except the bathroom. On another note, all the gas appliances save the water heater work with one flaw for the furnace (Subarban nt 22 c). It appears the gas valve doesn't shut off completely and the burner has a small bit of flame when the thermostat kicks off. I converted it to gas and electric and was using electric only till today. I will be posting how to do the electric/gas conversion after I make sure all is well and safe using the gas with the electric add on. My only concern is with how the wiring holds up as the gas tends to heat the entire furnace more than straight electric would. If all works properly you would be able to add electric heat to your existing system for around $40 to $75 bucks (used parts). Always nice to have the alternative in case the gas runs out in the middle of the night.
