Old 09-28-2013, 11:28 PM   #15
1964 26' Overlander
Cedar falls , Iowa
The plumbing seems pretty straight forward... Accept for where the leak is at. Is that a rule? I only saw it leaking from around the back sink/ shower area. The po ran pex so it shouldn't be that hard should it?
Bluemoon64 is offline   Reply With Quote
Old 09-28-2013, 11:29 PM   #16
1964 26' Overlander
Cedar falls , Iowa
However they said it leaked everywhere
Old 09-28-2013, 11:43 PM   #17
1964 26' Overlander
Cedar falls , Iowa
I have already learned so much on the fly.... The awning wasn't even set up the right way when I first took the picture. Live and learn.... As long as it mo harm no foul.
Old 09-29-2013, 04:15 AM   #18
RM66caravel's Avatar
1966 17' Caravel
Newport , North Carolina
Pex is good but can be installed wrong so just check the connections. There is nothing that you can not repair and no the plumbing is not at all that difficult. Just start slow and check the connections first, start at the fresh water tank then work to the first tee. Stop at that point and go to the city water inlet and check from there to the same point you stopped at from the water tank. If that is all good then easy points (kitchen sink) then water heater and last bathroom. I hope that this is not too confusing as I am only half awake and will reread this later!
Cliff
Gotta get busy! Have a great day! Now where did I put those revits?
RM66caravel is offline   Reply With Quote
Old 09-29-2013, 12:28 PM   #19
2008 25' Safari FB SE
Campbell , California
I am soooo jealous! By the time I get a trailer, I'l have been reading the forums for years . . .
mykabyka is offline   Reply With Quote
