Old 03-05-2014, 06:49 PM   #29
1973 29' Ambassador
Riverside , California
Remove all insulation today. Want to start on replacing the subfloor.
santina is offline   Reply With Quote
Old 03-05-2014, 08:50 PM   #30
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
The floor is the best place to start!
Old 03-05-2014, 09:46 PM   #31
1973 29' Ambassador
How do I replace it? Is it a piecemeal replacement?
Old 03-05-2014, 09:54 PM   #32
1973 29' Ambassador
Any good links for the steps involved in subfloor replacement. Taking out the entire shell seems intimidating. Please advise me on the alternatives I want to get started with this project within the next few days
Old 03-05-2014, 10:52 PM   #33
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
You only need to replace what is weak and rotten.
I ended up replacing a full sheet in the bath.
I ended up using a second sheet pieced in around the front windows and under were the refrigerator was.
Old 03-05-2014, 10:54 PM   #34
1973 29' Ambassador
So do you you mean the subfloor has to be taken out in patches? I would like to replace the whole floor (maybe the OCD in me )
Old 03-05-2014, 10:55 PM   #35
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
I did not remove the shell, and I only dropped the belly pan under the black tank and bath.
I replaced the floor that needed replacing only. 80% of my floor was sound.
Old 03-05-2014, 10:58 PM   #36
1973 29' Ambassador
Could you give me a brief step by step? so the bolts must be removed from the c-channel and a new cut of plywood replacing it. Bolts are removed from below?
Old 03-05-2014, 11:00 PM   #37
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Is your floor trashed?
If not, why would you think that new plywood is any better than the wood that has already lasted 40 years?
Be careful diving into a project. Lots of people start very aggressively and never get their projects back together.
I have six months of labor in my trailer and only spent a couple or a few days on the floor.
You just started a big project , I recommend not making it bigger than it needs to be.
Old 03-05-2014, 11:08 PM   #38
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Look on profile in my posts on the forum. One of my first few posts was on a thread called "Lotsa water damage".
There is a description and photo of what I did on my floor.
Old 03-05-2014, 11:14 PM   #39
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
The volte will almost for sure be so rusted that they will break.
I used a circular saw to cut the rotten sections of floor first , thereby giving me Access to both the nut and the bolt.
Old 03-05-2014, 11:59 PM   #40
1973 29' Ambassador
I thought changing the floor would also give easy access to the tanks. I wants to for sure change the tanks. Is there another rote to access the tanks?
Old 03-06-2014, 12:07 AM   #41
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Where do I start with my 73 ambassador
Both tanks will come out of the bottom.
Look for frame rust through near the black tank before getting too far along.
I replaced 4 feet of frame on the back of my trailer, it turns out that doody water is pretty corrosive.
It must have been leaking for decades.
Old 03-06-2014, 12:08 AM   #42
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
I replaced my black tank and adder a grey tank to my trailer.
1966 Airstream Sovereign 30 - Georgia riess.a Airstream Classifieds 0 01-27-2014 06:25 PM
Where do I start? slo-an Full-Timing 9 01-08-2012 06:47 AM
2004 LY *Won't Start, No Power* Help RAG General Motorhome Topics 15 12-27-2011 03:41 PM
Ambassador :: 1971 Airstream Ambassador nascar427 Airstream Registry Discussions 0 08-19-2011 10:07 PM
