Old 05-31-2008, 03:03 PM   #1
mok
MOK
North Providence , Rhode Island
What size
Any thoughts on what I can tow with a Jeep Grand Cherokee with the 5.7 hemi rated for 7200 lbs?
mok is offline   Reply With Quote
Old 05-31-2008, 03:26 PM   #2
1986 31' Sovereign
Miami , Florida
Pretty short wheelbase and you don't want to go much beyond 80% of your rated capacity or 5760#. Pretty much leaves 16' or 19'. Older are lighter than newer. Also need to consider what misc gear you'll be dragging around in the back of the jeep.
mike
Old 05-31-2008, 04:44 PM   #3
Whizzo's Avatar
2014 23' FB Flying Cloud
San Antonio , Texas
Images: 18
Medium-sized V8 SUVs can be good tow vehicles, as long as you're being reasonable on trailer length, and using a high quality Equalizer-typr, dual-cam type, or Hensley type hitch. The wise members of this group will alway caution you on your Jeep's 110 inch wheelbase. I have a comparable vehicle in wheelbase size (114 in) and tow rating (7,000 lbs), and it tows the 22 ft well (trailer 3680 lbs loaded). With the larger V8, you'd have plenty of power/torque, but for handling and control a good antisway hitch is mandatory. I certainly wouldn't go any bigger than than a 22.
2014 Flying Cloud 23FB
2015 Ram 1500 EcoDiesel
Whizzo is offline   Reply With Quote
Old 05-31-2008, 05:43 PM   #4
mok
MOK
A local dealer is telling me I should be able to do the 23' Safari SE - 6,000 pounds. Sounds like the Hensley could make that a lot easier?
Old 05-31-2008, 05:50 PM   #5
Whizzo's Avatar
San Antonio , Texas
Images: 18
Yes, it would. It's a signficant cost over other hitches, but many feel it is worth the investment. There's a great Hensley-Arrow resource right here on the group, to help you decide if you want to go that direction:
http://www.airforums.com/forums/f464...ide-26279.html
You'd still be pushing the weight a bit at that much of your capacity, and would need to really watch how much you carried in both the TV and the trailer.
what size a/c? RichardT Furnaces, Heaters, Fireplaces & Air Conditioning 1 04-15-2008 08:30 PM
What size AC/Heat for 31 Ft. AS. Dugger10 Furnaces, Heaters, Fireplaces & Air Conditioning 8 03-20-2007 11:55 AM
TV size? tport40 2007 Safari SE 7 03-01-2007 05:54 PM
Twin Size Size Over59 Upholstery, Blinds, Walls & Interior Finishes 5 08-20-2004 10:18 AM
What size do I need? Tin Hut Batteries, Univolts, Converters & Inverters 3 04-07-2004 06:30 AM
