Go Back   Airstream Forums > Airstream Community Forums > Our Community > Member Introductions
Old 10-24-2013, 07:22 PM   #21
Alumaholic's Avatar
2019 27' Flying Cloud
Albuquerque , New Mexico
Images: 36
Yep
Originally Posted by Moak View Post
Ok, update, got the 110 working, all outlets & what appears to be a converter for the batteries . 2 brand new batteries but NO juice to ant if the lights. Main power does not display anything. Is there a main switch I'm missing?
There will be a battery isolation switch, normally a solenoid with a rotary switch but sometimes just a household 120 VAC toggle.
Your 12 volt lights and appliances won't work til you find it.
Ken L
2019 Flying Cloud 27FB
2020 GMC Sierra 1500 Crew Cab 6.2L Max Tow
Four Corners Unit WBCCI #5783
Alumaholic is offline   Reply With Quote
Old 10-24-2013, 07:51 PM   #22
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
my 77 Sovereign had no switch but did have the big glass fuses 50amp or 30amp I can't remember which but they looked good but were bad,replaced them and clean fuse connection up a bit and 12v worked fine.
Mike
desertair27 is offline   Reply With Quote
Old 10-25-2013, 08:42 AM   #23
Alumaholic's Avatar
Images: 36
Likewise
Mike
Come to think of it, I had same experience on a '76 Safari 23. Big 30 amp cartridge shaped fuse.
Ken L
Old 10-27-2013, 08:04 PM   #24
Moak's Avatar
1977 31' Sovereign
Hanford , Ca
Replaced all the 50 amp fuses. Found out I have no power from the panel to the main box, (shows battery, tank status ect. Anyone know how to get to the wiring harness ? Just can't figure this out
Moak is offline   Reply With Quote
Old 10-27-2013, 08:15 PM   #25
Alumaholic's Avatar
Images: 36
There isn't a wiring harness per se.
There is 120 VAC wiring from the breaker box in the rear of your trailer that is only hot when you plug into shore power,
And there is 12 VDC wiring from the DC distribution panel (where you found the fuses) to all the the 12 volt lights, and appliances (furnace, fans, water pump, etc,)
The point where 120 VAC and 12 VDC meet is at the converter-charger, in your case an elderly Univolt that needs to be yanked out and replaced with a Iota DLS-55.
P.S. You still have not found the 12 volt isolation switch.
Wish I was there to help.
Ken L
Old 10-27-2013, 08:56 PM   #26
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Are you sure you have power to 12v fuse panel? What about that isolation switch?
You'll learn the ins and outs of your trailer before you know it. It is frustrating when the simple things don't cooperate.
How bout adding some pictures of the various things so when can see what's going on. I'm no expert but always willing to share what little I know.
Mike
Old 10-27-2013, 09:18 PM   #27
Moak's Avatar
1977 31' Sovereign
Hanford , Ca
Are you sure you have power to 12v fuse panel? What about that isolation switch? You'll learn the ins and outs of your trailer before you know it. It is frustrating when the simple things don't cooperate. How bout adding some pictures of the various things so when can see what's going on. I'm no expert but always willing to share what little I know. Mike
I'm sure I have power at the 12v fuse panel but I DONT KNOW WHAT AN ISOLATION SWITCH IS. I also don't know how to do a personal message
ID:	198851   Click image for larger version
Old 10-27-2013, 09:49 PM   #28
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
I don't have the isolation switch myself so I don't know either. Click on the person you want to PM and you'll see where you can pm that person,usually at the bottom of the page.
Great pictures by the way.
I would double check power to fuse panel with a test light or meter.
Old 10-27-2013, 10:42 PM   #29
1989 34.5' Airstream 345
Ebro , Fla Panhandle
Have you put a battery charger on the batts that you found? They may or may not be charging from the 110 AC . An outside charger will assure that they get charged. This may help get the 12 volt system going.
I am a newbie here also. So my suggestions are with out any vintage AS experience.
Cool story of discovery. Good luck with your new trailer, keep us posted on the progress.
Cheers Richard
tevake is offline   Reply With Quote
Old 10-28-2013, 06:17 AM   #30
Sneakinup's Avatar
1977 31' Sovereign
Tampa Bay , ^
Images: 123
My 77 Sovereign also does not have an isolator switch... at least none that I have ever found. I had issues with my panel having burnt connections, wires hanging, and melted fuse holders. I rebuilt the panel completely with 2 new fuse blocks and 2 heavy duty 50 amp LED fuse blocks that they use in high end auto audio systems. Now every circuit is working perfectly. Even my antiquated Airstream control panel is all lit up. Prior to me changing out the panel, things only worked sporadically.
I also picked up an intelligent charge controller for the Iota 55 amp converter. Now all systems are a go.
ID:	198881   Click image for larger version
Out in the woods, or in the city, It's all the same to me.
When I'm drivin' free, the world's my home....When I'm mobile.
Sneakinup is offline   Reply With Quote
Old 10-28-2013, 08:18 AM   #31
Alumaholic's Avatar
Images: 36
Nice job Sneak in up!
Ken L
