Old 10-03-2006, 01:39 PM   #1
1986 29' Sovereign
Meredith , New Hampshire
Water Leaks
We are experiencing water leaks that seem to be coming up from the floor and into the carpets; we have a 1986 29' Sovereign. These leaks are in the middle of the floor with no overhead leaks! Any ideas?
danielpat53 is offline   Reply With Quote
Old 10-03-2006, 02:26 PM   #2
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
Check your sewer vents on the roof, there's a rubber gasket in there.
Remove 4 screws simple.
'77 Sovereign Intl 31' CB
Old 10-03-2006, 03:03 PM   #3
FT RVing
lebolewis's Avatar
1976 31' Sovereign
Always searching for a place w/low Humidity , FT RVing, N & S, E & W, & in between
Sewer Vents
UGH......another sewer vent strikes again!!!!
The rubber gasket that seals the vent pipe opening on the roof rots and splits......and then it leaks when it rains. The water runs down your sewer vent pipe and into the carpet around the opening where the vent pipe goes through the floor. You almost NEVER "see" this happening! And it runs on to the plywood sub-floor and then under your carpet and water soaks your carpet pad! ....... and many times, it runs on through the hole in the subfloor and into your holding tank pan.....where it slowly rusts and rots your tank pan!!! It's a slooooow process and you rarely ever notice it until it's too late!!! It can do major damage!! Been there, done that!! Bill
lebolewis is offline   Reply With Quote
Old 10-03-2006, 04:45 PM   #4
1986 29' Sovereign
lebolweis - thanks for the tip. Will get up on the roof first thing in the morning. Now I will have to buy my wife a new carpet!
Old 10-03-2006, 04:46 PM   #5
1986 29' Sovereign
Lipets - thanks for your help
Old 10-03-2006, 05:29 PM   #6
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
If you have to replace the carpet take a look at the floor, if it looks bad maybe replace with something else, carpet holds moisture. Rots floors
Old 10-04-2006, 06:01 AM   #7
1986 29' Sovereign
Bob,
Great advice - will pass along to the boss
Water leaks 53flyingcloud Our Community 2 11-28-2002 01:07 PM
travelling w/out water system maznblu Fresh Water Systems 6 09-09-2002 12:03 PM
Water leaks Craig Fresh Water Systems 3 08-08-2002 01:44 PM
Finding water leaks FrankR Plumbing - Systems & Fixtures 0 06-27-2002 08:36 AM
Looking for ideas hot water FrankR Water Heaters, Filters & Pumps 3 05-09-2002 10:28 AM
