Old 07-17-2019, 06:34 PM   #1
2018 22' Sport
San pablo , California
Water leak .. newbie
I got my AS attached to city water and i discovered leak herr as shown in the picture. So i turn the cvity wster off, i pressed thr pump button in thr panel and drained the water. How do i prevent this leak from happening again if i want to be just connected to city water
ID:	346948   Click image for larger version
Clarque2003 is offline   Reply With Quote
Old 07-17-2019, 06:49 PM   #2
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Well, here is your problem.... you need a new water pump. The check valve in your water pump that prevent water from the city hook up side is bad. Water is back flowing from the city water side to the tank. Once the tank is full the water is then flowing out the freshwater tank over flow. Changing the pump out will fix the problem.
If your trailer is the 2018 sport you have in you discrption then it should be covered under warranty.
Dept of “OverKill”
Old 07-17-2019, 07:01 PM   #3
dznf0g's Avatar
Oswego , Illinois
If its warranty, fine. If not disassembly and cleaning the crud out of the check valve usually fixes. Probably a small piece of tank shaving has gotten past the strainer.
-Rich-
Old 07-18-2019, 09:28 AM   #4
Airstream Ambassador
AirstreamInc's Avatar
Jackson Center , Ohio
Hi Clarque2003,*
Please send us a direct message with your contact information and the last 6 digits of your VIN so we can share it with our Customer Service and Technical Support team. We look forward to helping you get this resolved.
You can also reach Airstream Customer Service and Technical Support at*customer_support@airstream.com*
Thank you.
Official account for Airstream, Inc.
Airstream Customer Service and Technical Support can be reached at 1 (877) 596-6111, option 1.
AirstreamInc is offline   Reply With Quote
Old 07-19-2019, 07:02 AM   #5
Long Island , New York
Conversation continued in the new thread:
http://www.airforums.com/forums/f443...ie-198389.html
Old 07-20-2019, 08:58 AM   #6
2018 22' Sport
Hi. The last 6 digits ofnour VIN is 542110 airstream 2018 vlf class mr 22 sport
Newbie water pump/leak question rlhendren Water Heaters, Filters & Pumps 8 11-22-2016 03:36 PM
That darned leak!! Need help from leak experts !! nickclifford General Repair Forum 20 12-03-2015 05:52 PM
Leak then no leak. gandttimes Leaks - Weatherstrips, Gaskets, Caulks & Sealants 0 10-04-2013 01:34 PM
Leak: Fired Up Hot Water, Now There's A Leak SSChanger Fresh Water Systems 4 07-15-2009 08:46 PM
possible plumbing leak or water leak jamesl Repairing/Replacing Floor &/or Frame 1 04-06-2003 10:52 AM
