Old 02-23-2006, 02:16 PM   #1
hantri's Avatar
1973 31' Sovereign
1963 19' Globetrotter
Graham , Texas
Warm Welcome
Thank you all for the warm welcome. I know there will be many questions to come.. First is...we need a door lock '73 Sov. Does anyone refurbish old locks. This is probably a question for a different thread. Any guidance will be appreciated. Happy Day J & M
hantri is offline   Reply With Quote
Old 02-23-2006, 02:25 PM   #2
rebel beck's Avatar
1975 31' Sovereign
Oxford , Mississippi
Images: 35
We have a 75 and our door lock is needing to be replaced. Okay here's the shocker I have found these replacements anywhere from $149 up to $350.
But just this week I heard from this forum about a place where you could get it for $90 it is George Sutton RV 541-686-6296 and talk with Sean. Also these locks need to be fabricated in some way to work. Hope this helps.
And also welcome to the forums.
Becky
rebel beck is offline   Reply With Quote
Old 02-23-2006, 02:26 PM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Hi hantri,
There are SOME and I emphasize the some parts available for the KT locks. My local locksmith was able to rebuild mine. If yours is missing or broken your only recourse is to spent several hundred dollars for an orginal or buy a different version and use the patch plate. Here is the kit, they run in the $200 range.
Good Luck and let us know how you make out.
Aaron
WBCCI #XXXX AIR #2495
Old 02-23-2006, 04:59 PM   #4
hantri's Avatar
1973 31' Sovereign
Graham , Texas
Thanks for the info. We have the outside portion but I believe we are missing an inside handle of some kind. Look forward to looking at some vintage units..
How warm is it? Heat wave in Ohio! Rallytime? Jim Jarzabek Off Topic Forum 0 02-15-2006 06:37 AM
WBCCI Survey smily WBCCI Forum 33 11-13-2005 09:08 AM
staying warm at 7000 feet silverback Winter Living 4 11-04-2005 03:09 PM
warm outlets markus Electrical - Systems, Generators, Batteries & Solar 5 11-29-2003 04:06 PM
Tiny fan to bedroom of Sovereign helps cool and warm the space Joan D'Andrea Cabinets, Counter Tops & Furnishings 2 11-02-2002 11:10 AM
