Old 09-12-2009, 01:53 PM   #1
1970 29' Ambassador
Euless , Texas
TX Newbie 70 Ambassador
First of all, thank you to all who take the time to share their knowledge at this site. You gave me confidence and helped me to step into a totally new world. We are blessed with rain in TX today, which has allowed me to discover 3 leaks on my 70 Ambassador. Therefore, I will close for now to search out the solutions for stopping the leaks.
tx70amb is offline   Reply With Quote
Old 09-12-2009, 06:33 PM   #2
Alwhisman's Avatar
1978 Argosy Minuet 7.3 Metre
Dayton , Texas
Images: 94
Send a message via Yahoo to Alwhisman
Welcome to the forums. Congrats on your acquisition. We are enjoying the rain as well!
Good Luck!
Al
Alwhisman is offline   Reply With Quote
Old 10-01-2009, 09:13 PM   #3
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
Find those leaks and patch them with 'clear' LEXEL caulking. Stay with us and leaks or not- we're all in this together.....
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 10-14-2009, 11:43 AM   #4
1970 29' Ambassador
Euless , Texas
The leaks are slowing down
I am still here. The antenna leak is gone, I removed the old antenna and patched with alum circle. Used Vulkem to seal and rivets to hold in place. My first reivet job. Two vista windows are now cleaned and sealed with Vulkem on top side and ParrBond on the sides. I hope my AC leak is solved. Found 3 holes drilled in outer skin when compressor mounting plate was installed. When enough rain collected on AC deck, it would run into the holes. I am also repalcing weather stripping as I go and using the D shaped product sold by Island RV. Had a tough time removing the dreaded flat snap ring on window pivot arm.
Old 10-23-2009, 06:37 PM   #5
1970 27' Overlander
Yeah, that little 'itty'-bitty-tiny-einie-wiennie-little (%#@) We replaced a window not too long ago and that little ring took forever to get off!
Old 10-24-2009, 08:23 PM   #6
1970 29' Ambassador
Euless , Texas
Round two with the AC leak
With 5' of rain, I discovered the AC area still leaked. Water weeps in on the edges of the compressor mounting plate that is itself mounted to the AC deck. I cleaned up PO attempt to seal the area and hit it hard with Vulkem. If I do not have the leak solved now I am in real trouble. My other leak is at the front window and it seems to be coming in the weep hole. Perhaps I have front end of trailer tilted up. Will search past forums for weep hole discussion.
Old 10-24-2009, 08:28 PM   #7
1970 29' Ambassador
Euless , Texas
I must have posted my reply incorrectly since I do not see it here. AC area leaked with 5" rain last week. I discovered the leak is on the sides of the compressor mounting plate that is mounted to the AC deck. Cleaned up PO attempt to stop leak and hit it hard with Vulkem. Will find out tomorrow if that solved the problem, if not I am in trouble. I will now search the forums for front window leak at weep hole. I may have front of trailer too high which allows water to run back in versus draining out.
Old 10-26-2009, 02:10 AM   #8
Victorialhq's Avatar
1991 34' Limited
we will go with our hearts , Texas
Hi I am a TX newbie too no trailer yet but in the process
Victorialhq is offline   Reply With Quote
looking at '63 Ambassador amcclaran Member Introductions 5 04-11-2009 07:14 AM
'67 Ambassador...Is this the one?? LucyPepper Trailer Values 9 05-01-2008 11:38 AM
'79 Ambassador questions from a newbie mjjnorman Member Introductions 4 11-29-2007 11:44 AM
'71 Ambassador Margehly Member Introductions 3 07-19-2006 01:33 AM
63 ambassador jrussell Member Introductions 1 07-10-2006 02:38 AM
