Go Back   Airstream Forums > Airstream Community Forums > Our Community > Member Introductions
Old 08-27-2006, 11:31 AM   #1
1978 30' Argosy 30
Anchorage , Alaska
Trouble with pipes in Alaska !
Dear reader. BP isn't the only one having trouble with pipes in Alaska !! We are having woes with ours as well. The water pressure in our "78 Airstream has been good up until a few months ago when all of a sudden when we would turn on any tap we would hear a groan from the intake area and the water would shut down to a trickle. This problem healed itself over and over again and the pressure would be fine but the self-healing ceased and we removed a check valve hoping the problem would be solved, alas to no avail ! There is still something that groans back there and we are at a loss. Perhaps there is another check valve lurking unbeknown to us disguised as something else, because we cannot find it !!
What we need is a plumbing diagram. If anyone can assist with any ideas it may save us from tearing our hair out. Oh by the way we are hooked up to town water.
Cheers...Christine in Anchorage.
bradleys is offline   Reply With Quote
Old 08-27-2006, 11:57 AM   #2
Round on both ends
SafeHarbor's Avatar
1979 31' Excella 500
1975 28' Argosy 28
Rutledge , Georgia
Hi, Christine,
Locate your city water pressure regulator. It looks sort of like a big propane welding regulator. Gently tap it with the plastic part of a screwdriver and see if anything happens.
If your's is a rear bath, I think it's in the utility closet, perhaps under a pull-up floor.
Many of these old regulators don't work so well anymore. A lot of the folks here on the forum, myself included, use an inexpensive Marshall in-line regulator out at the spigot. These are less than $10 in the RV department at Wal-mart.
And welcome to the forum, of course. It's going to be interesting to hear how you fare if you plan to winter in the Airstream. Hey, what do I know about Alaska? Is it winter there already?
Lamar
1975 Argosy 28 "Argosy"
1979 Excella 500 31 "Betsy"
1992 Lincoln Mk 7 LSC
2003 Dodge 2500 Cummins "TowHog"
"Lucy Loosehair" the cat - Airstream mascot
Klaatu barada nikto
SafeHarbor is offline   Reply With Quote
Old 08-27-2006, 05:13 PM   #3
1977 27' Overlander
alexandria , Kentucky
what about fixing the valve under the shower of a 77 Overlander without taking the shower out.
Vic Terry is offline   Reply With Quote
Old 08-27-2006, 07:00 PM   #4
Round on both ends
SafeHarbor's Avatar
1975 28' Argosy 28
Rutledge , Georgia
Hi, Vic,
Welcome to the forums! So Airstream was evil enough to put a valve UNDER the shower? I don't know WHY that surprises me.
I'll let someone who has a clue answer this one, but do feel welcome. We're glad you and frozen chosen Christine have come to join us.
Lamar
Klaatu barada nikto
Old 08-28-2006, 10:18 AM   #5
1978 30' Argosy 30
Anchorage , Alaska
Thanks so much for your reply but unfortunately there must be another valve somewhere as that one was already removed. Cheers...Christine.
Folding step trouble, 1977 31' Sovereign JohnGalt48 Steps 13 09-10-2011 06:45 PM
Black & Grey valve trouble camphost Waste Systems, Tanks & Totes 51 08-18-2006 08:45 AM
Grease seals, hub trouble Silver Annie Axles 10 11-03-2002 11:46 AM
Alaska PeterH-350LE On The Road... 11 09-04-2002 07:57 AM
12V trouble.... Chuck Electrical - Systems, Generators, Batteries & Solar 8 07-06-2002 04:57 AM
