Old 08-26-2007, 09:00 PM   #1
1986 25' Sovereign
matthews , North Carolina
towing 25' with a 4.L jeep grand
I have a 1986 25' airstream and am curious if anyone has expierence with towing it with a jeep grand cherokee with tow package. Its rated to 6500 and the stream weighs 4900 dry. Thanks for any advice.
monbro54
monbro54 is offline   Reply With Quote
Old 08-26-2007, 09:03 PM   #2
More than one rivet loose
thecatsandi's Avatar
Los Alamos , New Mexico
what is the maximum loaded weight of trailer? how about the Jeep?
going by the 80% rule, 5200# should be the maximum weight you tow.
I know several members tow a 19 with a jeep but nothing bigger.
Michelle TAC MT-0
Sarah, Snowball
Old 08-26-2007, 09:07 PM   #3
CanoeStream's Avatar
St. Cloud , Minnesota
Hello monbro54 - Welcome to the Forums!
The Jeep product have a short wheelbase and 4L is a small engine. Those translate into issues as far as stability and ability. The general answer is 'not enough tow vehicle.' Do a search on Grand Cherokee and you will be able to pick out a number of discussions on this issue.
5 meter Langford Nahanni
Old 08-26-2007, 09:54 PM   #4
Janets Husband's Avatar
1977 Argosy Minuet 6.0 Metre
1964 26' Overlander
1977 25' Tradewind
Eastern , Washington
Campcollector used to tow his 19' Bambi with one, and has some very scarey stories about the subject. Just not enough vehicle with a very short wheel base. I would say not a good idea.
Peace
Gary
Janets Husband is offline   Reply With Quote
Old 08-26-2007, 11:15 PM   #5
urbanfood's Avatar
1956 22' Flying Cloud
Venice , California
no way i'd tow that 25' with a grand cherokee, as previously stated, it's not enough of a tow vehicle. i'd recommend spending some time in the towing sub forum and you'll quickly understand why.
david
*by asking the above question,
i verify that i have already used
the search feature to the best of my ability...
urbanfood is offline   Reply With Quote
Old 08-27-2007, 06:34 AM   #6
Royce's Avatar
Colorado Springs , Colorado
I tow a 3500# (wet) Minuet using the Wrangler with the 4.0L six, NV4500 tranny, Prodigy controller, and an Equal-i-zer hitch . Your GC has a longer wheel base and that will help some. I havn't experenced any issues with handling but the 6-7% grades we can find here in Colorado will slow me down to 45 MPH and second gear real quick. Even a slight grade will require shifting out of OD. You may be able to tow the coach but likely will not be happy with the performance. I wouldn't recomend it.
ducking and hiding now to avoid the flames
Royce (K0RKK) 146.460 simplex
Web page http://spearfishcreek.net/
AIR# 3913
'77' Minuet 6 Metre, behind a 2005 stock Jeep Rubicon with Equa-L-Zer hitch.
Royce is offline   Reply With Quote
Old 08-27-2007, 06:41 AM   #7
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Welcome to the Forums. We're glad to have you with us. The TV/TT combination that you are proposing is not even close to my towing comfort zone. A short wheel base six cylinder vehicle is not a good match for any heavy trailer.
SuEllyn & Brian McCabe
Old 08-27-2007, 06:41 AM   #8
StingrayL82's Avatar
San Angelo , Texas
Images: 37
Kiss that automatic transmission goodbye, if you're going to tow that trailer. The only good automatic transmission Mopar ever made was the Torqueflite 727. That Grand Cherokee might have a "tow package", but that tranny isn't beefed up from the factory, and Grand Cherokees were notorious for having tranny problems anyway. If you're a Mopar fan, look into getting a good used 1500 with manual transmission to tow. Keep in mind that a lot of the Grand Cherokees also had A/C problems, so if you do decide to tow with it, and it's summertime, consider rolling down your windows.
Frederic
Frederic
1971 Sovereign International - SOLD
2004 F-350 King Ranch
AIR # 8239
EX-WBCCI # 8371
StingrayL82 is offline   Reply With Quote
Old 08-27-2007, 08:49 AM   #9
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Jeep Tow Vehicle
Our Jeep tow vehicle experience is limited to the 85 Grand Wagoneer 360ci V/8 we used to tow our "63" Safari. Even with that trlr. we were right on the limit, no reserve power, poor mi.etc. Looked pretty good but wasn't a very good t/v.
Name:	STREAM'N IN NEW ENGLAND.jpg
“We were young and knew nothing...now we're old and everyone else knows everything.”
RLC
"It is more wiser to ponder all things with diligent suspicion, than follow with blind assumption."
RLC
"Tahawus"
Old 08-27-2007, 09:37 PM   #10
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
GVWR for my '86 corner bed/mid bath is 6800 lbs. I wouldn't tow it with a Jeep Cherokee due to lack of power and short wheelbase. I've had one idiot pull out in front of me and I had to brake hard. The trailer pushed my '01 2500hd ext. cab rear end a little to the left while I steered slightly to the right to avoid him/her by one foot. I layed on the horn the entire time while doing this. I guess this is why my passenger side horn does not work anymore. Gotta get that replaced this weekend. Oh, brakes are much better now with the Tekonsha P3 controller.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 08-27-2007, 10:49 PM   #11
USN/LAPD Retired
Safari-Rick's Avatar
North Las Vegas , United States
Here's the bottom line...
I had a 4.7L V8 Dakota Quadcab modified with air injection, computer chip, 180 degree thermostate, catback system. It gave me about 20 more fl lbs of tork. Even with that I always was worring about going up hills, traffic, over heating the motor/tranny, and not being able to use my AC on those hot summer days.
Max speed was 45 with full throttle going up most hills. Oh, I also used synthetic oils all around.
I was always worried about the weight limit. Just too Too much stress when I'd take the 25 AS Safari LS out. Couldn't just load up and be happly on my way. On a trip to Lake Tahoe and Yosemite, the exhaust manifold blew going up hwy 121 from the north side.
My tranny was ok but, that probably because I changed out the fluid each year.
So, the bottom line is, do you want to enjoy your trips? or do you want to worry if you're going to blow the engine, tranny, etc? and in your case weight?
R/
Rick
2007 Dodge Ram Quadcab 6.7L Diesel w/jakebrake
"Better to have more then you need, then need more then you have because you don't have enough!"
AIR #: 8129
Safari-Rick is offline   Reply With Quote
Old 08-28-2007, 05:39 AM   #12
1986 25' Sovereign
Allegan , Michigan
Get the REAL weight
I recently purchased an 86 25 foot unit - the old one needs a bit more help than I could give it this summer. Anyway, comming home I weighed the trailer and truck - then the truck separately. While the title weight was 4900 lbs the actual weight was 5320 - including about 50 lbs propane. With the trailer loaded - including a full water tank - it was about 6100 lbs.
Years ago I used to tow a 5000 lb 24 foot trailer with a full size station wagon with 120 inch wheelbase and a 6 litre engine. It worked OK but it did slow down on long hills. I currently have a 3/4 ton truck with a diesel - much more enjoyable but I notice that the 86 is about 1000 lb heavier than the 75 model. A bigger issue is brakes - most trailer brakes are not very good even when well maintained. A heavier tow vehicle - with good brakes - makes up for some of that. But, as has been pointed out, you need to be aware of the limitations.
Good luck on whatever you decide.
Whit Nash
rwnash is offline   Reply With Quote
Old 08-28-2007, 06:35 PM   #13
davidz71's Avatar
1986 25' Sovereign
Whit,
Did you get the rear twins or the corner bed/mid bath?
Craig
AIR #0078
3.73 rear end
Old 08-28-2007, 10:55 PM   #14
Motoman's Avatar
2005 25' International CCD
1960 18' "Footer"
Riverside , California
Monbro, here is a copy of a post of our experience towing a 2005 22' CCD with a 1996 Jeep Cherkoee and full factory towing package that I made to the "Tips for Smaller Truck/Smaller Trailer Combinations" thread. I don't think my reply was appreciated since the original poster considered a Tahoe a small tow vehicle!
Our first Airstream really hit the Smaller Truck/Smaller Trailer Combinations. We towed a 2005 22 ft CCD with our 1996 Jeep Cherokee, 6 cylinder with 5000# factory towing package for the first six months we had the Airstream. We used the Equlaizer hitch and experienced no stability issues with head winds, side winds or bow waves off passing 18 wheelers. I should note that I did have to re-adjust the hitch after driving home the first night from the dealer. They had the ball too high and not enough preload on the weight distribution bars. The Jeep settled in the back while the front came up an inch or so!. After proper adjustment the back settled about 1 1/2 inches, the front 1 inch.
We noticed the lack of power on the steep grades out of the Los Angeles basin on I-15 and I-10 freeways. Both have long upgrades that exceed 20 miles and several thousand feet. We could easily maintain 55 mph but were turning 4000 RPM in second gear. Water temperature stayed about 210 on those steep grades. What would cause a problem was when passing truck traffic would slow everyone down; it was difficult to build speed back up without pulling out in the fast lane and slowing other traffic. We did not have any trouble maintaining the speed limit going into Death Valley from Baker but Jubliee Pass was quite steep and twisty so the 20 MPH speed limit was welcome in our Jeep. That said our neighbors couldn't go more than 20 MPH in their 8.0 liter SOB motorhome either.
The Jeep did very well on our maiden trip to Joshua Tree. We drove about 50 miles in 4 to 6 inches of snow in 4 wheel drive with the Airstream in tow the day we left! We never did tow with this combination in the summer heat having bought a larger tow vehicle in the Spring.
in retrospect, towing the CCD with the Cherokee was very similar to towing travel trailers back in the 60's and 70's; you had to slow down on long steep grades because you didn't have a choice.
What I didn't mention in my original post was that we saw water temperatures as high as 230 degrees going into Joshua Tree on a 70 degree day. The grade was extremely steep and the speed limit 35 MPH so we didn't get much air through the radiator from road speed. We didn't experience any overheating or radiator boil-over but I would not like to repeat those conditions on a 90 to 100 degree day. We still have the Cherokee and now a 25' CCD but we pull it with a Dodge 2500 Ram diesel. I'll go through the Cherokee cooling system, install a larger transmission cooler and use it to tow our 18 footer when is ready to roll.
Don (KD6UVT) & Gail Williams
What do you want to be in life, a spectator or a participant?
SNU #157
FCU #004
Motoman is offline   Reply With Quote
Towing Experience app Tow Vehicles 9 04-19-2004 09:51 PM
towing with Roadmaster/ Fleetwood Cruiser On The Road... 1 09-26-2002 04:14 PM
Towing COArgosy78 1969 Overlander 5 09-05-2002 10:18 AM
Towing cars CBBOB Airstream Motorhome Forums 13 07-24-2002 08:15 PM
Towing a small 60s trailer with a SUV... Andy R Tow Vehicles 15 03-30-2002 07:57 PM
