Old 05-04-2006, 08:30 AM   #1
Safari 1999-present
1999 25' Safari
Port Huron , Michigan
Post Tow Veh in 2007/8
New forum member. Member WCBBI but not active.
Looking for tow vehcile in late 2007. 4 doors, power, gas mileage. Pull 25 ' Safari 1999.
llebpmac is offline   Reply With Quote
Old 05-04-2006, 08:49 AM   #2
Images: 59
llebpmac,
Welcome!
Are you looking for recommendations for a new vehicle, or are you interested in buying a used one from someone on the forums?
Old 05-04-2006, 09:00 AM   #3
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
Hard to say what fuel will be like in a year or so. If I was back in the midwest, looking at gas powered vehicles, I would look at a flex fuel (E85) pickup truck. But, diesel would be my first choice. They are expensive to start, but do pay for themselves and then some, over time.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 05-04-2006, 09:23 AM   #4
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Trailblazer (extended version w/V8), E85 Suburban, or a diesel pickup or SUV all with between 125"-135" wheelbase (or longer).
Old 05-04-2006, 09:42 AM   #5
myoung's Avatar
Nipomo , California
Images: 24
For what it's worth, we pull a 2006 25' Safari that may weigh a bit more than yours with a 2005 Dodge Durango all tricked out with the tow package and every other option except the DVD player. We also have the standard rear axle ratio and with that combination we regularly get 12.5 to 13.4 mpg on regular gas while towing. Around town we get 17+ mpg and our best mileage on the highway has been 23.8 mpg. Not bad for a 5,200 pound 4-wheel drive automatic transmission SUV that is short enough to serve as a daily driver.
I believe that most people would suggest buying used rather than new. Let someone else take the depreciation charge driving it off the lot.
Good hunting. Lots of choices.
Mike Young & Rosemary Nelson
Bowlus Road Chief "Endymion"
BMW X3 xDrive 28D
myoung is offline   Reply With Quote
Old 05-04-2006, 09:56 AM   #6
Airstream25's Avatar
1995 25' Excella
1982 34' Limited
Albuquerque , New Mexico
Images: 21
Send a message via Skype™ to Airstream25
Rumor has it that GM dropped the 8.1L in the 2007 SUVs. If true, this might be another reason to buy "used".
Airstream25
KE5CKG on 2 meters
AIR #10274
Airstream25 is offline   Reply With Quote
Which is best tow vehicle Van or Sedan? Mr Jody Hudson Tow Vehicles 10 10-06-2016 09:14 PM
Tow Vehicle Options wlanford Tow Vehicles 10 05-23-2005 12:18 PM
tow vehicles paul k Tow Vehicles 96 01-19-2003 09:59 PM
1975 Cadillac Eldorado as Tow Vehicle overlander64 Tow Vehicles 9 11-04-2002 07:04 AM
Tow questions ALANSD Airstream Motorhome Forums 3 05-28-2002 09:51 AM
