Old 05-29-2015, 07:28 AM   #15
2015 25' FB Flying Cloud
Charleston , South Carolina
Another question, and I'm sure there will be more, can anyone give me opinions on the pros/cons or single vs. double axle?
Bonnie
BKuhlman is offline   Reply With Quote
Old 05-29-2015, 08:06 AM   #16
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
Weigh it...
Originally Posted by BKuhlman View Post
If someone has modified a TT, how do you determine the new weight if you are looking to purchase and need to know tow weights? For instance, if someone has added granite in the kitchen and bath, that adds a LOT of weight.
Bonnie
Wherever the trailer you're considering might be, there should be a nearby truck stop, moving company, or whatever that has a CAT scale. These can weigh a big truck (movers charge by the pound, truckers deal with load regulations). Easy enough to weigh an Airstream there, assuming that the trailer is in a towable condition.
Airstream owners use these scales to adjust their tow hitch settings. You can deal with that once you've chosen your trailer.
Old 05-29-2015, 08:15 AM   #17
Plasma800's Avatar
houston , Texas
Bonnie
Well double axle will carry more weight on the axle, bonus, if one tire goes, the other can keep rolling for a moment.
Down side, harder to twist the trailer sharp, but that's a small downside cause you almost would never do it.
'15 27fb Signature
'12 Chevy 2500HD Gasser
Plasma800 is offline   Reply With Quote
Old 05-29-2015, 09:25 AM   #18
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Bonnie
That granite would be removed within the first few days were it mine. Some things aren't meant to be. The cabinetry isn't made for that weight.
Understood your question regards changes by an owner. Still, the factory weight is decent starting point for purchase of a used TT. A few hundred pounds here or there really won't change anything unless the tow vehicle is genuinely marginal. Most will not be so. As a worry it really doesn't count for too much.
Water damage is still the big one. That, and a fire behind the walls.
HELP! TOTAL Newbie seeks polishing advice! '70verlander Cleaning, Stripping & Polishing 6 08-12-2009 07:34 AM
Total newbie w/'77 24' Argosy w/oapaddle All Argosy Trailers 28 06-28-2007 10:00 AM
total rank newbie here... katzklaw Member Introductions 10 12-18-2006 07:12 PM
Total Newbie tntim Member Introductions 4 05-27-2006 08:50 AM
(total newbie question)Compressor/Airbags in a 76 argosy 24? 76Argosy24_Thomas Mechanics Corner - Engines, Transmission & More... 4 11-12-2003 01:08 PM
