Old 11-05-2006, 02:32 PM   #1
1972 25' Tradewind
Cascade , Maryland
Took a Dive into the Deep End!
Greetings all,
I thought I'd better post a quick introduction, as I suspect that I will be in regular contact with many of you for quite some time. I just brought home my 1972 Tradewind AS, and am looking forward to many interesting projects and conversations over the next several years. I don't have any pictures yet, but I'll try to get some soon, and I'm certain that you all have some great advice to a first time Air Stream owner, as seen throughout the pages on this great site... Kudos to the creators and hosts.
Of course, what is a post without a question...
As I brought this unit home, I was in a follow vehicle (I don't even have a hitch for my truck yet), and noticed water coming from the back rear. Now I did have the unit inspected, and they indicated that there may be some leaks, though the previous owner swears that the connections are just loose, as he did that to prevent damage. Long story short... how does one go about draining all of the water out of the system so that things won't freeze. For the life of me, I can't find a drain plug anywhere.
Anyway, happy travels, and I look forward to "meeting" many of you.
Paul Pinkerton
Cascade, MD
Pinkerton is offline   Reply With Quote
Old 11-05-2006, 04:46 PM   #2
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
Our models are not the same - I have a '72 Globetrotter. The drain for mine is located under my curbside sofa, inside the trailer. You may have to trace your plumbing a bit.
Good luck, and welcome to the forums! Lots of great info here.
Dave
Fyrzowt is offline   Reply With Quote
Old 11-05-2006, 04:50 PM   #3
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
Look for two drains in the pipes. Not always two, but worth finding if there are.
The drain for the fresh water tank is a little more difficult. It will be down in a well cut into the floor, usually under the sink cabinetry. It may be just a petcock, like you used to see on evaporative cooler supply lines. It takes a day and half to drain the tank...
Zep
Old 11-05-2006, 05:21 PM   #4
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
Welcome to the Forums!
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
Old 11-05-2006, 08:46 PM   #5
1972 25' Tradewind
Cascade , Maryland
Question Curbside
Thanks for the suggestions. You've given me some other places to look, now all I have to do is get some daylight to do so. The neophite that I am, has to ask 1 very key question. When you say Curbside... is that the side the door is on (and thus the curb when driving) or do I have it backwards?
Thanks again.
--Paul
Paul Pinkerton
1972 Tradewind
Cascade, MD
Old 11-05-2006, 08:49 PM   #6
1975 31' Sovereign
1977 23' Safari
funny how all the connections are on the 'street' side. yes, curbside is the door side and the side that's closest to the shoulder when you're driving (in the right lane).
Zep
Old 11-05-2006, 09:03 PM   #7
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Zep
Hi, yes, but it wouldn't be too funny if all the connections were on the curb side. That would put my sewer connection under my kitchen window. And I think they figuered out if all the connections were on the street side, it would be very difficult to hook up your RV while parked on the street.
Old 11-05-2006, 10:51 PM   #8
cameront120's Avatar
1972 25' Tradewind
Welcome! Excellent choice of trailer!
North Vancouver, BC
Old 11-06-2006, 01:53 AM   #9
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
Welcome to the forums and congratulations on your new trailer. If I remember correctly with my old Tradewind the drain was located under the trailer on the belly below the fresh water tank, midway street side.
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 11-06-2006, 09:11 AM   #10
1972 25' Tradewind
That's correct. I just drained mine last week. If the OP wants to drain his lines, the easiest way to do that is to open all the water lines (there are 3 valves located in the cabinet below the galley sink and one or two at the rear, either in the compartment behind the toilet or in the streetside wardrobe). Also open the taps to the kitchen sing and shower/sink. Attach an air hose to the water connection at street side and blow compressed air through the lines. Also, don't forget to drain the water heater! If you don't have an air compressor, the owner's manual says you can open all the valves as mentioned above and raise and lower the front of the trailer with the tongue jack to drain out the water. I hope this helps.
North Vancouver, BC
Old 11-07-2006, 12:06 AM   #11
CaddyGrn's Avatar
1963 16' Bambi
Yreka , California
Welcome to the forums and congrats on your Airstream!
I am not familiar with your model, but cameront120 has an excellent suggestion. We have a couple of drain pipes in our 1963 Bambi, but my hubby completely re-plumbed everything last year. Even though much of ours drains well, when winterizing, he blows all out with an air compressor. Be sure you don't over do the pressure and blow out stuff you don't want to damage! If you can't find the drains, etc. post questions and maybe someone will have pics of theirs that is similar you can view!
Enjoy your new 'stream
Mrs. NorCal Bambi (traveling in S Tardis)
CaddyGrn is offline   Reply With Quote
Old 11-07-2006, 07:34 AM   #12
1975 31' Sovereign
1977 23' Safari
you can't hurt your plumbing with a standard shop air compressor, which have max pressures of 125 psi. PEX will withstand 400 psi and copper even more.
You can, however, hurt yourself. Once the system is pressurized with air it contains lots of stored energy, so if something did happen to come apart, it would do so in a very violent and high velocity manner. Water at the same pressure is much safer--since it's incompressible, only a small leak will result in instant loss of pressure and consequently, force, so something full of water might burst, but there's no violent flinging involved.
Zep
Old 11-10-2006, 05:01 PM   #13
1972 25' Tradewind
Cascade , Maryland
Cool
Thanks for the replies and the welcome. Tomorow I will dive into this project and find all of the various drains... I hope. I do have an aircompressor, so I just might try that method.
Paul Pinkerton
1972 Tradewind
Cascade, MD
Old 11-11-2006, 03:00 PM   #14
wannaroam's Avatar
1978 31' Excella 500
Harmony , Pennsylvania
Images: 36
Paul : From one new owner to another, congratulations and welcome!
If you are able to get your hands on a copy of the manual for your unit I would highly recommend it. We have a CD version of the one for ours and it has helped tremendously knowing where everything is and how it goes together (and comes apart).
wannaroam is offline   Reply With Quote
Saggy Bottom ( rear end ) smily Repairing/Replacing Floor &/or Frame 127 10-01-2006 08:28 PM
Off the deep end... blackboat Member Introductions 13 05-30-2006 06:39 AM
deep cycle battery replacement 26Argosy.ca Electrical - Systems, Generators, Batteries & Solar 6 01-02-2003 05:19 AM
How deep am I getting? jade_stone General Interior Topics 10 09-18-2002 10:04 AM
End Joints in New Floor melprice Floor Finishes 3 07-12-2002 11:16 AM
