Old 10-15-2017, 09:49 AM   #43
wave man's Avatar
2018 25' Flying Cloud
Houston , Tx
Thanks folks, points noted and appreciated!
Men are but men, and the greatest men are they who soonest learn the simpler things. ROBERT E. HOWARD
What a man does for pay is of little significance. What he is, as a sensitive instrument responsive to the world's beauty, is everything! H. P. Lovecraft
wave man is offline   Reply With Quote
Old 10-19-2017, 05:12 AM   #44
2017 27' Flying Cloud
Frederick , Maryland
One thing I thought I would add. Several people have noted that an expired credit card is a good thing to use in order to unstick the window from the rubber seal. I just wanted to add that those little plastic things that stores/gyms give you for their "clubs" or discounts are typically on key rings and work great. Since we got our trailer a few weeks ago I've probably used my Golds Gym tag for that more than actually going to the gym! :-)
DewTheDew is online now   Reply With Quote
Old 10-19-2017, 12:13 PM   #45
wave man's Avatar
Houston , Tx
Question Okelly Dokelly
Alright! The FC 25 was in great shape to my eyes.. and 2 teens running all over it so I'm happy as a clam.
However the WD hitch they put on is kinda big, maybe ..not sure.
Literature that came with it says it is a 1,200 lb Hitch... it's rated for a maximum tongue weight of 1,400 lbs & max gross trailer wt of 14,000 lbs.
Have seen opinions that with a new 2017 F-250 a lighter WD Hitch may be preferable...
Do you think this WD hitch too heavy for a FC25FB ?
That it will be leading to rough ride or harsh on the FC on the road?
Any possible reasons to not use this one ?? This FC has a 837 lb expected dry and basically empty tongue weight, and I've seen some people talking about maybe 1,000-1,100 lbs tongue weight possible when put into use and loaded.
Any other real world, in use, loaded tongue weights out there for comparison folks?
Old 10-19-2017, 01:34 PM   #46
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Austin (winter) Lincoln MT (summer) , Texas & Montana
Take your time before delivery...
Lots of good advice here for sure! We owned 2 25's before purchasing our first "new" 2012 25FC Twin model back in 2012! The older models all worked well, because the previous owners fixed all the factory issues, no doubt! With our first new 25', we were so anxious to get on the road, we neglected to really "look over" the outside skins, as well as letting the service tech show us how everything worked. We later found a couple scratches and a small "ding-dent" in the skins. Also, the water pump was extremely loud with pipes rattling when turned on. Had we checked the water pump we could have gotten them to show us how to wrap the pipes with insulation, which we learned about later. I agree to run all the systems. if there is no water in the system to test the pumps, add some water while still there...if possible, tell them you want to spend the night to verify all systems are working...some dealers will do this on their lots; others may have a place near by. Problem is, once you sign the papers, it's yours...so get as much checked out as you can. We took delivery of a new 2017, 28' twin in June and had to drive to Oregon to take delivery from dealer. We loaded it with our belongings the day before delivery on the lot, and were able to test out the systems while loading it. Batteries were not fully charged, so we caught that. Everything else worked, however. We did end up having batteries replaced couple months later when they would not stay charged. Interstate detected bad cells and replaced free. Now we just replaced the Converter with a 4 stage model to insure that problem does not happen again. Good luck!
2017 28' Twin Flying Cloud
2017 F250 King Ranch, 4X4, Blue-Ox WDH
Summer in Lincoln, MT- Winter in Austin, TX
gypsydad is online now   Reply With Quote
Old 10-19-2017, 01:43 PM   #47
gypsydad's Avatar
We had a Blue OX Swaypro with 1000# bars on both of our 25's; the 2008 and the 2014 models and had it adjusted properly with our F150 with no issues ever. We now have a 28' with 1100# tongue weight, and went up to the 1500# bars. Thought they were too tight at first, but after adjusting properly and weighing on truck scales, everything is fine. The initial stiff ride has smoothed out considerably over past 5 months and 7K miles pulling with our F250. I would think 1000# bars for a 25 would be the right ones.
Old 10-19-2017, 01:48 PM   #48
2007 22' International CCD
Unsticking the gaskets from the glass is easy with a piece of thin plastic, like a credit card, but be very careful not to bang the edge of the tempered glass with a metal object of any sort--like the key ring!. Tempered glass will easily shatter if the edges are damaged!
Another good method is to unstick it, and wipe the gaskets with an RV Trailer 303 Aerospace protectant wipe (to leave a thin film of silicone on the gasket). There is also a product called "Window Poppers" that can be installed to easily push the glass open from inside...a quick Google search should get you to both products...
KE4GNK/AE
rmkrum is online now   Reply With Quote
Old 10-19-2017, 10:26 PM   #49
wave man's Avatar
Houston , Tx
Question
No feedback for my concerns expressed in post # 45 ?
I'm trying an Eaz-lift Recurve (R6) , they suggested it, said local Airstreamers were coming in and switching to it...who knows.
I liked it's simplicity, but the bars seem heavy as I remember people talking about a 3/4 ton TV with stiffer suspension and a FC25FB...needing lighter bars
I don't want to waste time making costly mistakes that will delay me getting to enjoy my Airstream
Old 10-20-2017, 07:05 AM   #50
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Without experience with that hitch it's hard to comment. Based on posts here, it's not one that many people have. That's in no way to say it's a bad hitch. It may well be the best hitch on the planet. It's just not one that most of us have seen. If the next set of bars on that hitch are 500 lb tongue and 5,000 lb tow then the 1,200 lb bars may be correct ....
Old 10-20-2017, 09:20 AM   #51
wave man's Avatar
Houston , Tx
Ahhh I see... a wrinkle to iron out. Swell hehe
Old 10-20-2017, 09:29 AM   #52
wave man's Avatar
Houston , Tx
I know that these things have models/bars rated max wt 800, 1,200 & 1,400 lbs(which they gave me)
If I understand it correctly I should have the lightest bars that will still handle the heaviest tongue that an FC25FB will get.
And maybe lighter, being a new 3/4t Ford. It's said they may not need as much WD, and the trailer may thank me for lighter bars.
Is my understanding correct thus far here at least?
Old 10-21-2017, 07:11 AM   #53
Half a Rivet Short
Hi
You don't *need* WD on a F-250 to meet Ford's specs for towing. Put another way, the rear end will not fall off the truck / back axle break if you don't have a WD hitch. On some trucks, you will do damage without WD. That's different from it being a pleasant ride or being safe in terms of sway.
All hitches I have seen like yours are adjustable. You fiddle them to get things "right" in terms of load balance. You then fiddle a bit more to get things right in terms of handling. Not everybody has enough patience (or the tools) to do this. Until you complete the adjustment process to the point of "handles like I want", you really don't know which bars are correct. If you run out of adjustment range, then they are the wrong bars.
I woud see how things adjust out and go from there ...
Old 10-21-2017, 08:51 AM   #54
Mollysdad's Avatar
I bought mine off of dealer inventory, so I had a chance to inspect it several times.
By the walk through, and having other RV's I thought I knew something. But driving away, I still regretted not asking a million more questions. Like, "Show me how to tell if the propane tanks are full and how do I switch tanks?"
Bring a DVD with you and ask to see how to get audio from the DVD player onto the TV. (It may be super easy, but I don't know even today)
Make hot water, not just talk about it. Is the WH in bypass?
Flush the toilet. It sounds silly, but mine is electric. We discussed it, but I never saw it work.
I don't know how to test the furnace when it's 90 degrees outside during the walkthrough.
Look closely at all the shades and knobs for missing parts. That's the only flaw I found and they fixed it before I got there.
Of course, all is covered by warranty, but I'll be learning on the road. My bad.
Are they selling you a hitch or are you bringing your own? Who's setting it up? Electric brake controller?
Did you remember tow mirrors? I did, then forgot to take them out of the box. Your mind is spinning when you finally pick it up, it's hard to be perfect.
Old 10-21-2017, 09:26 AM   #55
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Best advice I can offer for that is, if it's hot outside, use the A/C to cool down the interior, then use the furnace to warm it back up.
If it's cold outside during the walk-through, use the furnace to warm the interior, then use the A/C to cool it back down.
Only way I can think of to test both the A/C and the furnace during the walk-through.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 10-21-2017, 05:17 PM   #56
Hi
The problem for some of us who haven't towed much is "what is it that I'm adjusting for?" Does it feel good or bad? I'm not sure; it doesn't pull me all over the road and I don't porpoise too much, but could it be better? Not sure. For me it was the same with adjusting the trailer brakes. I think they are okay but I'm not positive since I don't have much in the way of experience for comparison
New time streamer, long time dreamer Wilburstream Member Introductions 25 01-12-2009 08:32 PM
To 'Time Delay' or not 'Time Delay' FordTruck Jacks, Stabilizers, Lifting and Leveling 11 05-20-2008 02:58 PM
A time to buy, a time to sell jeffyockey@m Member Introductions 2 03-12-2008 10:39 PM
first-time poster.....long-time reader ("lurker") happyfella Member Introductions 3 08-21-2006 08:55 PM
Part Time vs Full Time (Days/Year) InsideOut Community Polls 30 10-23-2005 09:43 AM
