Go Back   Airstream Forums > Airstream Community Forums > Our Community > Member Introductions
Old 03-26-2006, 12:20 AM   #1
Jack Martin
Profile:  1964 19' Globetrotter
Calistoga , California
Taking chance on first and only trip...
I'll bet this question won't sit well with some of you, but I'm going to ask it anyway...
I have a farily long ride (400 miles) to make with a newly purchased 1964 Globtrotter 19' behind a Chevy Silverado 1/2 ton. It will be the trailer's one and only highway voyage. I am considering making the ride with a ball hitch only- no sway bars, no brake controller. How slow would I have to go to avoid problems with stopping, swaying, etc... I know if I only went 10 mph I'd be fine. I know if I went 50 mph I'd have problems. Where's the break point?
I'd go 20 mph if I had to, if that would keep me in control. Am I nuts? Thanks.
Jack
Jack Martin is offline   Reply With Quote
Old 03-26-2006, 12:32 AM   #2
SilverToy
Profile:  1992 34' Limited
Falls Church , Virginia
Gamblin' man....
Jack -
Welcome to AS forums. What a way to introduce yourself!?!!!!
What you are proposing to do is really rather foolhardy. For yourself, your property, your LIFE (potentially).
Not to mention if someone else gets hurt by your actions.... can you say lawyers?
Do the right thing. Get your truck outfitted properly. Who knows, maybe you'll enjoy the towing experience so much that you'll want to do it again, and again and again.....
If you do go ahead with your aforementioned plan - be sure to post time and dates, SO WE CAN ALL STAY FAR AWAY FROM YOU AND YOUR AS!
Hope you make the right choice here!
See ya -
Axel
SilverToy is offline   Reply With Quote
Old 03-26-2006, 12:59 AM   #3
Jack Martin
Thanks Axel...
The problem is, I'm not really a gambling man. If I took all local roads and went 20 - 30 mph all the way, might I survive? I promise I'll tell you when I'm leaving...
Old 03-26-2006, 01:11 AM   #4
SilverToy
Maybe more than you realize...?
Jack -
If you are serious about your question, then perhaps you are more of a gambler than you realize....?
My advice is DON'T DO IT. Can't help with the speed part since it isn't really anything I would contemplate, much less recommend or advocate. Sorry Jack.
Consider the tires and bearings before you undertake moving the unit.
Seriously Jack, do the right thing here! For all the right reasons! Too much can go wrong with this scenario.... Please reconsider!
My 2 cents
Axel
Old 03-26-2006, 01:47 AM   #5
Jack Martin
I am reconsidering...
Axel -
Thank you for your well placed concerns. I have already replaced the tires, and the bearings were recently repacked. I will be purchasing a brake controller, and probably investigating sway bers.
You see, I'm not really a gambler. Certainly not with my life, or yours.
Thanks again. Your comments were taken very seriously, and were very helpful.
Jack
Old 03-26-2006, 03:21 AM   #6
dwightdi
Profile:  1977 31' Sovereign
McHenry , Illinois
I have been known to limp home without brakes for 400 miles after they failed on the road and could not get repair parts. This is a pretty small rig and a reasonable size truck so I think you could get away with it. It still would likely be considered illegal. If you have no experience towing, then this is a poor way to learn. I would drive as fast as it seems still feels you are in control. If it feels scary slow down. If you go too slow the police will likely think there is something wrong and stop you.
Old 03-26-2006, 03:37 AM   #7
clancy_boy
clancy_boy's Avatar
Profile:  2003 22' International CCD
1966 17' Caravel
Kiln , Mississippi
Images: 8
My experience in December.
Jack,
I don't want to say I did the same thing - but I sorta did. Bought my Caravel on EBay and had to go to IN to get her. The first thing I did was search the internet for trailer repair locations near my pickup point (40 miles). I called them and made arraingements for a complete inspection. I bought a new spare on the way, the trailer service center installed my electric brakes and did a good inspection. No real problems with the running gear were found and all it cost me was $179 for the brake controller and installation with inspection. They repacked one set of bearings. I also had a complete set of bearings w/ seals in the truck with a shop jack just in case. Good set of tools were extra insurance.
The other thing you might want to do is call your insurance agent and inform him of your purchase. Tow vehicle insurance covers the trailer BUT they may need to be informed first.
Good luck - I went 700 miles but had done some precautionary prework in advance.
Mike
Old 03-26-2006, 08:30 AM   #8
Darol Ingalls
Darol Ingalls's Avatar
Profile:
Run Chicken Little, the sky is falling again! Your pickup and a 19' Globetrotter will do just fine with a little caution. If the tires are good, bearings are OK, and you have the correct size hitch ball (2"), safety chains, brake and turn signals (you are doing this in daylight, I hope) you will have no legal or towing problems. Look at all the big boat trailers being towed by small SUVs with nothing better than a glorified bumper hitch. Your Globetrotter weighs less than many boats of the same size and lots of those don't have brakes or sway control. Don't get in a hurry, drive defensively, and enjoy the trip.
Darol Ingalls is offline   Reply With Quote
Old 03-26-2006, 08:46 AM   #9
flyfshr
flyfshr's Avatar
Profile:  1959 24' Tradewind
Phoenix , Arizona
One other item that will be highly recommended is a break away switch. Most states require this. If your trailer becomes unhitched, the brakes engage on the trailer. Also, I would recommend the use of towing mirrors so you can keep an eye on what's going on back there.
FF
WBCCI/VAC #2699
Air #10
I'm haunted by aluminum.
http://www.airztream.com
http://59tradewind.blogspot.com
flyfshr is online now   Reply With Quote
Old 03-26-2006, 09:09 AM   #10
blucloud
blucloud's Avatar
Profile:  1987 25' Sovereign
North Olmsted , Ohio
Images: 20
JACK,
Your globe Trotter weighs approximately 3000#. Have you ever tried to stop a 3000# trailer, without auxilary braking, quickly from 40mph? Secondly, most states require some type of auxilary trailer breaking on units over a certain weight. (surge or other). A brake controler is the best insurance for a safe trip.
As for the hitch setup .... do you have any fellow campers that would let you borrow a their WD hitch for the trip?
Whether you tow your trailer with proper equipment or not, or being careful when doing so, it will always be the unexpected actions of the other vehicles that cause problems.
Just my opinions ....Dave
Jack ....I have an extra brake controller that you may have if you would PM me your address.
You never know what you can do
until you try to undo what you did.
blucloud is offline   Reply With Quote
Old 03-26-2006, 09:23 AM   #11
StingrayL82
StingrayL82's Avatar
Profile:  1971 31' Sovereign
San Angelo , Texas
Images: 37
Jack,
I have personal experience with this matter. I bought my 1971 Sovereign 31' off of Ebay last year. I towed it with my 1997 Dodge Ram 2500HD 5.9L gas engine. No brake controller, no sway bars, no equalizer bars....nothing. I towed it all the way from Marblehead Lakeshore, OH to where I live, in MD. Eight hour trip. I stopped overnight at a truck stop to get some sleep, so the trip took me two days. Aside from the stop, I took it easy, set the cruise on 55MPH and went down I-80, I-76, to I-70 home. I never once had a problem. The Airstream towed straight as an arrow and never once swayed on me, not even on the PA Turnpike, as the 18-wheelers were flying past me. These silver bullets are incredibly aerodynamic, and I foresee no problem with you towing yours home, especially a 19 footer. As long as you're hitched on good and tight and you have safety chains, and you don't drive like Ernie Irvan, you'll be fine.
Frederic
P.S. The brakes on my Sovereign didn't work anyway, and the Dodge stopped just fine. Just remember to allot yourself extra stopping distance.
SSG Frederic Lynes
1971 31' Sovereign, restored
2004 F350 King Ranch
StingrayL82 is offline   Reply With Quote
Old 03-26-2006, 09:34 AM   #12
sigv
sigv's Avatar
Profile:  1963 24' Tradewind
Pittsford , New York
Jack,
No expert here but I picked up my 24' Tradewind in NC (I am in NY), towed her home with no electric brakes in the rain and snow. No problems whatsoever. Did not go crazy on the speed (about 65-70).
Good luck and don't sweat it.
-Sig
sigv is offline   Reply With Quote
Old 03-26-2006, 09:45 AM   #13
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
HI Jack,
I have towed my now sold motorcycle trailer loaded with 2 bikes (3000# total) from FL to OR and back TWICE with no incidents using a Chevy 1/2 ton van once and my new Dodge Sprinter van. Trailer was not equipped with brakes and had no WD or sway devices......just the hitch and the ball. Follow the speed limits and always anticipate the extra time needed to slow down. Had no problems either with sway or braking. All Interstate travel.
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
lewster is online now   Reply With Quote
Old 03-26-2006, 10:12 AM   #14
CanoeStream
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
Restating what has been said before: Each state has specific laws requiring on-trailer brakes once you go over a certain weight. You will have to have tail lights working on the trailer, so why not brakes? I changed out my Argosy's old umbilical plug for a modern 7-pin in a cold rain when I picked it up. You just have to go prepared. Sounds like a need for a brake controller .... and you did ask!
Second -- 400 miles is a long way to tow in one day at 55mph (but is frequently done ...). At reduced speeds you might need to plan an overnight somewhere.
'64 Globetrotter, eh? Enjoy!
CanoeStream is online now   Reply With Quote
