Old 03-30-2014, 05:03 AM   #1
Bullit's Avatar
1971 18' Caravel
Nokesville , Virginia
Still new, still starting
Joined AF last year some time thinking about starting a restoration of 71 Cara Elle that my family has not used in 20-30 years. May actually have to move it this week. I believe it will take a flat bed or low boy to trailer it the 200-300 miles to my current location. Will try to post should I take the dive...
Sent from my DROID RAZR using Airstream Forums mobile app
Bullit is offline   Reply With Quote
Old 03-30-2014, 06:03 AM   #2
Birdie Momma
NJtoNC's Avatar
1957 26' Overlander
1956 22' Flying Cloud
Rutherford Co. , North Carolina
Wow, cool that its been in your family for so long. Why do you need to flat bed it? Where is it now? Do u have other pics? Would love to see inside.
'57 Overlander | '56 Flying Cloud | '51 Spartanette
NJtoNC is offline   Reply With Quote
Old 03-30-2014, 06:32 AM   #3
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
Just repack the bearings, put new tires on, temp lights, check the coupler & safety chains & tow it. You'll be fine.
Colin
Colin H is offline   Reply With Quote
Old 03-30-2014, 01:25 PM   #4
Bullit's Avatar
1971 18' Caravel
Last time I was in there, the interior was good. I have been motivated to move the trailer because an area entrepreneur decided to supplement his income be mining precious metal from the vast amount of copper under the cabinetry. Sorta feel like he helped get the initial demolition started.
As for towing this gem, the wheels were about half hurried in the ground and the axle may have had some contact with the associated moisture. Thinking it is probably worth flat bedding breather then risk the inconvenience of a catastrophic towing incident.
Have included some illustrative pictures of both. Interior is through the window as I did not have key last time I was there to dig out the wheels for replacement.
Old 03-30-2014, 01:32 PM   #5
Bullit's Avatar
1971 18' Caravel
Pics
ID:	208584   Click image for larger version
Old 03-30-2014, 01:43 PM   #6
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
That low to the ground the axles and frame could be bad - so flatbedding is probably a good choice.
I've seen two bad stories about hiring "pro's" to do the trip. In one, they put strapping over the top of the Airstream and the bouncing of the trip put permanent dents in the aluminum - pretty much ruined the trailer. In the other the driver towed it at about 70 mph, and the strapping through the axles and frame got loose or broke through the rust, I'm not sure. At any rate the trailer was saved only because they got the driver to slow down, stop and pull over.
So consider renting a low-boy utility trailer and bringing it home slow and safe.
Looks like you do have a nice shell for a beautiful "dinky-twinky" though. I wish you a successful low-stress rescue trip.
Paula
Old 03-30-2014, 01:46 PM   #7
I don't envy you the job of digging out those wheels! I'm feeling the ants and spiders crawling up my arms just thinking about it. Bug bomb the whole area the day before you start digging!
Paula
Old 03-30-2014, 02:55 PM   #8
RM66caravel's Avatar
1966 17' Caravel
Newport , North Carolina
Door looked as if someone had used a pry key on it! I am with Colin replace the tires repack the bearings (reverse order) then slow and east tow it home you can check the axle when you dig it out. Jack under the frame point (scissors jack) not the axle. When you raise it put the jack stand under frame on the other side of the wheel. Loosen the lugs first but then you already knew that.
Cliff
Gotta get busy! Have a great day! Now where did I put those revits?
RM66caravel is offline   Reply With Quote
Old 04-16-2014, 12:43 PM   #9
Bullit's Avatar
1971 18' Caravel
Well I have made the leap... or at least I have dug out loaded up and am currently heading south with the Caravel.
Old 04-16-2014, 12:43 PM   #10
Bullit's Avatar
1971 18' Caravel
Pictures to collow
Old 04-16-2014, 02:52 PM   #11
1966 17' Caravel
Looking forward to seeing the pictures!
Cliff
Old 04-21-2014, 08:02 AM   #12
Bullit's Avatar
1971 18' Caravel
pics of the move
Total time spent digging loading strapping hauling unloading etc... "Many". The evening I decided to begin this exercise it snowed in eastern PA. Worked through it and got the trailer on a flat bed despite it being about four in he's too wide. Improvised a sorta bed widening extension and headed out the next day. 8 hours of 45 mile an hour driving on back roads andwe made it home.
Really working on pics....
Old 04-21-2014, 08:08 AM   #13
Bullit's Avatar
1971 18' Caravel
Pics
Old 04-21-2014, 08:12 AM   #14
Bullit's Avatar
1971 18' Caravel
Finally figured this out.... again.
Will get some of the inside next time
ID:	210158   Click image for larger version
ID:	210160   Click image for larger version
ID:	210162   Click image for larger version
i'm new and starting a restoration. jessejane Member Introductions 10 08-17-2013 01:20 PM
Starting a new thread. edmonson Forum Admin, News and Member Account Info 1 03-10-2012 10:50 PM
Starting up trailer questions pompaneaux Electrical - Systems, Generators, Batteries & Solar 24 06-10-2010 12:08 PM
Starting off right with a new CCD 28' nangoff 2002 - 2005 International 8 07-24-2006 10:40 PM
Starting to look - welcome advice lwp999 Our Community 36 01-06-2003 05:58 PM
