Old 04-21-2014, 09:01 AM   #15
North West PA , Pennsylvania
Wow think how much that little gem is liking sitting in the sunshine after being hidden in
the shrubbish for so long!!!!! What a neat little trailer....good luck with your
restoration!
Laurie Count is offline   Reply With Quote
Old 04-21-2014, 10:16 AM   #16
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
What a cute little guy! Definitely worth the trouble to fix up. good luck, and come back whenever you have questions. Lots of folks have already been down the road you are starting out on, and will be able to advise you if you get stuck!
My first bit of advice - if you have the space, don't throw anything away. You can use the old cabinetry for patterns, and particularly any fiberglass inserts (like the bathroom) can be repaired and reused, and are almost impossible to find.
Stephanie
Old 04-22-2014, 01:23 PM   #17
Bullit's Avatar
1971 18' Caravel
Nokesville , Virginia
Made a clean spot. Skin looks to be in pretty good shape under the black slime. Found some rust. Sorta expected it, but its pretty bad. Completely rusted under the storage compartment in rear bumper...
Sent from my DROID RAZR using Airstream Forums mobile app
ID:	210277   Click image for larger version
Bullit is offline   Reply With Quote
Old 04-22-2014, 03:30 PM   #18
RM66caravel's Avatar
1966 17' Caravel
Newport , North Carolina
Ouch but it's all good if you like to work with metal you can get or have made the rusted parts and it is not all that expensive!
Cliff
Gotta get busy! Have a great day! Now where did I put those revits?
RM66caravel is offline   Reply With Quote
Old 04-22-2014, 08:39 PM   #19
Bullit's Avatar
1971 18' Caravel
Appreciate the encouragement. I am trying to remember that I expected the rust and it's just not that big'o problem. Mostly because it's not a big trailer. Thanks agaian
Old 04-23-2014, 05:53 PM   #20
Bullit's Avatar
1971 18' Caravel
Cleaned up the shell today and started removing "stuff" from the inside. Found lots of critter nests and related byproducts. Can't imagine there is any insulation left behind the inner skins? Removed the carpeting and discovered more floor rot and... black ants. Sprayed the area with a insecticide and am letting it soak. Most of the exposed floor looks pretty good.
ID:	210365   Click image for larger version
Old 04-23-2014, 06:06 PM   #21
Retired
tvketchum's Avatar
2008 30' Classic
Livingston , Texas
Is that an AM - FM - eight track system?
Tom
AIR 71620
WBCCI 5809 Reg 5 Unit 041
2008 Classic 30'
2013 F150 Ecoboost
tvketchum is offline   Reply With Quote
Old 04-23-2014, 08:12 PM   #22
Bullit's Avatar
1971 18' Caravel
Of course!
Old 04-24-2014, 04:16 PM   #23
Retired
tvketchum's Avatar
2008 30' Classic
Livingston , Texas
Originally Posted by Bullit View Post
Of course!
Well, Goodwill should be able to keep you supplied (ka CHUNK) with tunes.....
Tom
AIR 71620
2008 Classic 30'
2013 F150 Ecoboost
Old 04-24-2014, 04:44 PM   #24
Bullit's Avatar
1971 18' Caravel
Right on the middle of the best part of the best track
Old 04-25-2014, 06:12 PM   #25
Bullit's Avatar
1971 18' Caravel
Was looking at how my h difference a lil cleaning can do. Also found some interesting things in one of the cabinets
ID:	210530   Click image for larger version
ID:	210532   Click image for larger version
Old 04-25-2014, 06:36 PM   #26
laducky's Avatar
1978 28' Ambassador
Pacifica , California
Wow a little cleaning goes a lonnnng way on your trailer!! Great start.
Keep on truckin!
airstreamcalledtrouble.blogspot.com
laducky is offline   Reply With Quote
i'm new and starting a restoration. jessejane Member Introductions 10 08-17-2013 01:20 PM
Starting a new thread. edmonson Forum Admin, News and Member Account Info 1 03-10-2012 10:50 PM
Starting up trailer questions pompaneaux Electrical - Systems, Generators, Batteries & Solar 24 06-10-2010 12:08 PM
Starting off right with a new CCD 28' nangoff 2002 - 2005 International 8 07-24-2006 10:40 PM
Starting to look - welcome advice 999 Our Community 36 01-06-2003 05:58 PM
