Originally Posted by hatteras
Hi: I'm a "soon-to-be" owner of a 2005 31' Classic Dinette. I am confused about the GVW on this trailer. The factory says 10000; the present owner's manual says 8700. Any info regarding this, or any other factors of the 2005 31' would be greatly appreciated. Thanks
hi hat' and welcome to the forums and 'streaming...!!!
these to threads and associated links n pdf files will help u sort this '05 out....
and the 2nd link includes the specs/options and other details about 05 classics.
airstream math doesn't add up!!
http://www.airforums.com/forums/f296...res-27055.html
IF the unit production date is AFTER feb/march it likely has the higher ratings....
IF the unit production date is BEFORE dec/jan it likely has the lower ratings...
like bluebird notes,
the axles, brakes and larger segment protectors are mix n matched during the mid winter months, and...
along with the riveted plate OUTSIDE, there is a paper certificate INSIDE on the close door with these details too...
cheers
2air'
