mod streamer
i fully encourage you to use the tube for winter camping....and i think they work nicely for short trips into snow country. a few days or weeks is fun and its a treat to have your own condo near the slopes...
my first airstream was used regularly for skiing trips into british columbia, montana, washington and oregon. many ski lodges allowed boondocking in the parking lots and some within walking distance of the main lifts and lodges. now they usually have a parking lot designated for rvs and folks have great evening fun grilling outdoors!
yes you will use lots of lp gas and may need to take a trip down the mountain every 2-3 days for tank refills....just unhook the tank and go.
yes you will need to regularly vent moisture from inside with windows/exhaust fans and so on but if you are in a high/dry locale this is quick and easy. just be sure to do it mid day when the most sun and lowest humidity can help...
yes you may need a gen set to charge batteries but many ski resorts now have electrical power in the rv zones for a plug in. this also allow for using electric/ceramic or oil space heaters for extra warmth. make sure your extension cords are properly rated and as short as needed.
yes you need extra blankets and may want to sleep with woolie socks and a skullcap but that just adds to the fun.
be careful using the big awning if snow is falling as it can quickly become overweighted and collopse......ask me how i know.
take a big wisk/ship broom covered with an old think towel for knocking off big snow.....and be sure the door and window seals are silicon lubed so they don't freeze/stick closed or open....
http://www.airstream.com/airstreamer..._win_0301.html
yes since you are boondocking you'll need to be frugal with onboard fresh water.....but champagne and beer are meant for drinking anyway.
as long as you keep the heat on your water lines are safe as are the tanks....i didn't realize the waste water tanks weren't in the warm zone on the safari....are you sure? regardless the waste in the tank actually lowers the freezing point and you can always add some rv antifreeze to the tank which will further lower freezing point even when diluted some by gray/black things......
my only experience with a freezing line while ski camping.....apparently the shower trap in my older unit was exposed/uninsulated....so at 5 degrees or so the trap froze while i was showering.....that was exciting.
pulling a trailer on snowy roads is problematic but most resorts keep the roads very driveable for all the other crazies anyway....
so the reality of winter camping is a little extra prep and supplies for an otherwise fantastic trip in the silver palace......
go for it!!
cheers
2air'
check out these snow photos......
http://images.google.com/imgres?imgu...LD:en%26sa%3DN
