Go Back   Airstream Forums > Airstream Community Forums > Our Community > Member Introductions
Old 02-26-2006, 01:53 PM   #1
54cloud
Profile:  1954 22' Flying Cloud
sf , California
Question Searching for electrical info
Hello Airstream family,
My name is Dominic and I have the pleasure to restore a 54 Flying Cloud. There is one componet of the restoration that puzzles me though. The ELECTRICAL. I am slightly "green" when it relates to the DC or AC factors of the trailer. I have questions such as: " will dc power all lighting, receps, microwave and other appliances or does a 120v source need to be hooked up?" I am also concerned about maintaing proper codes throughout the trailer. Please post any comments of info that could help me throughout the process. Thank you vey much
54cloud is offline   Reply With Quote
Old 02-26-2006, 03:10 PM   #2
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 40
Your 54 will have very limited 12V wiring, most of the electrical would have been 110V in 54.
Since you are restoring your trailer, I suggest rewiring with as many12V circuits as is practical to you. Then, add a good quality battery and converter/charger such as the Intellipower 45A or 60A, and you're good to go.
check out my thread "a63 for me", I rewired my 1963 Overlander completely. It has all fans and light running on 12V now, so that it's function will be the same, boondocking or plugged in. I won't have A/C witout being plugged into a 30A outlet, plus my 12V outlets will not work, but everything else will function the same.
If you search the forums, using the search function, you will find more info on this than you ca digest in a month....
Good Luck with your project. A 54 Flying Cloud is definitely a worth while trailer to restore.
Uwe
Old 02-26-2006, 03:48 PM   #3
wkerfoot
wkerfoot's Avatar
Profile:  1979 23' Safari
1954 29' Liner
Orange , California
Dominic,
My 1954 Double Door Liner has no 12V wiring everything is 110V. I think you will find the same, and no battery in the trailer, in your Flying Cloud. Unless, of course, a prior owner added a battery.
Bill
Just my personal opinion
1973 Dodge W200 PowerWagon, 1977 Lincoln Continental
wkerfoot is online now   Reply With Quote
Other A/S info sharing sites Rog0525 Our Community 12 10-18-2002 11:09 AM
GREAT TECH INFO - good advice COArgosy78 General Repair Forum 6 10-11-2002 02:08 PM
Airstream info Rodger Airstream Motorhome Forums 3 07-03-2002 10:15 AM
Need info on A/C unit on a 1975 26 ft Argosy ... Hayseed Argosy Motorhomes 0 06-27-2002 09:19 AM
A/S Info ? well some good FrankR Our Community 1 04-26-2002 11:23 AM
