Old 04-12-2008, 09:52 PM   #1
1962 24' Tradewind
Pleasant Hill , Oregon
Rescued 62 Tradewind
It's not our first Airstream (that was a '66 Ambassador) nor anywhere near our first trailer. But this just-rescued 1962 Trade Wind 24 TS (SO743 - 6202) is the first one we ever felt like we "rescued" in the same way you rescue a lost puppy, a hungry kitty, or an injured bird.
Yeah, that's white paint peeling off the exterior. Lord knows why the paint is on there. (It's going to make the polish job just that much harder.)
You can find anything on Craigslist! After seeing the ad there, contacting the owner, and purchasing it for almost nothing, we went and got it this morning and towed it down out of an Oregon mountain campground where it had been moldering away. It sure needed a good home. ... It was nearly turned into a chicken coop! (the owner just didn't "get it", not being a trailer person at all. But she's a nice lady and she practically gave it to us.)
It's damp inside. The original interior is 3/4 gone, but it has bits of the galley and a lot of the twin bed area left. There are lots more pictures inside and out as we documented the "before" state of our rescue project. If you wanna see some more, just ask -- and we'll be putting some up in the 60's photo gallery soon. Hopefully it won't be too long before there are some "after" pictures to add, too!
All comments, advice, recommendations, etc. are welcome as we proceed to restore it. (You can email us directly at embark@earthlink.net if you wish.)
Oh, and thanks for letting us join this distinguished group. We're glad to finally be here.
Tom and Molly
Name:	April11-Rescued 62 Airstream.jpg
ID:	58078   Click image for larger version
embark is offline   Reply With Quote
Old 04-12-2008, 10:15 PM   #2
Hi Embark, welcome to the Forums, and congratulations on rescuing this trailer from imminent demise.
It's obviously tough to tell from the pictures and the paint, but it seems like the body is in good condition. Please be sure to post a lot of pics throughout your restoration process-- this one will obviously be an extensive remodel, and those are the best kind to document in a place like this.
Good luck on your project, looks like it will be a great one!
Old 04-12-2008, 10:16 PM   #3
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
glad it got a good home. Saw that on craigslist but decided the neighbors would kill us with a second one in the driveway. Look at it this way, if you plan to polish you'd have to strip it anyway, at least this way its really easy to see what you've done and what you haven't.
goransons is offline   Reply With Quote
Old 04-13-2008, 01:37 AM   #4
vinstream's Avatar
1962 19' Globetrotter
1963 19' Globetrotter
1961 19' Globetrotter
Wheat Ridge , Colorado
I saw this trailer too... From my experiance the old painted trailers, if not all dented up... will polish up nice... believe it or not the paint protects the Aluminum real well... Simply strip er down and off to the polishing gods..
Have fun... this should be a good trailer!
www.VINSTREAM.com
Wheat Ridge, Colorado
WBCCI # 1962
Instagram #Vinstream
vinstream is offline   Reply With Quote
Old 04-13-2008, 07:08 AM   #5
centennialman's Avatar
2016 20' Flying Cloud
Centennial , Colorado
The "poor old girl"!! She is so lucky that you found her and brought her to a new and loving home!
Steve "Centennial Man"
centennialman is offline   Reply With Quote
Old 04-13-2008, 08:43 AM   #6
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Nice find and rescue. Love to see more pictures as your progress progresses.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 04-14-2008, 09:49 AM   #7
1963tradewin's Avatar
1963 24' Tradewind
, , Minnesota
Nice trailer I love the tradewind Im in the process of getting mine done but keep running into road blocks. On my 63 it came with a compressor for the fresh water tank. I bought a shurflo water pump and replaced the compressor. Do I need the compressor as well as the water pump to operate the fresh water system? or is it not nessasary? any help would be appreciated thanks
1963tradewin is offline   Reply With Quote
Old 04-14-2008, 10:57 AM   #8
1962 24' Tradewind
re: compressor in water system
It depends, '63.With the presence of the old compressor as evidence, you might have that #%@*&% "closed system" that must be air-tight. Or do you have a "normal" system with a compressor to assist? If you have an air pressure guage and/or a hand airpump attached somewhere to your lines, it could be the closed system, in which case you'll prolly need a compressor. There are other ways to tell, such as an air "feed line" from your old compressor into your water tank. (Don't hook your Shur-flo to that line.) I believe that a compressor alone operates the system via that air pressure.
Some folks have had success with utilizing a downstream water pump by either removing the insides of the Schrader valve or keeping the fill cap to the tank loose (not the greatest idea). The best way is to re-orient your water supply lines so that you have an unrestricted, gravity flow to the intake on your Shur-Flo; and creating a small vent in the system, usually a breather hole in the fill cap, thus making your water system "normal".
best of luck,
keep us informed.
tom and molly
Old 04-14-2008, 11:50 PM   #9
1963 24' Tradewind
, , Minnesota
I dont know what I have nothing was there except the outside water cap did have a tire valve on it and the compressor was just laying in there. I ran all new copper and have a new rubber hose to the tank. just was not getting alot of pressure out of the tank but I didnt fill tank up all the way either lol Thanks for your help
Old 04-16-2008, 06:43 AM   #10
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Having a pressurized system for fresh water can be a pain unless everything is working properly. My '59 was set up this way without the compressor so it wasn't ever working properly once I got it. The aluminum tank was questionable with not knowing what had been put, stored or crawled in there. I also wanted more storage capacity than the original cylindrical tank. I switched out to a rectangular poly tank custom made from Inca Plastics. By doing this, I gained an extra 15 to 18 gallons. Since it wasn't going to be pressurized, the tank didn't need to have the strength of being cylindrical. For a tank vent, I removed the internal valve in the Schraeder valve on the water fill spout and drilled a small hole in the plastic cap. After I had gone this far plus adding a ShuFlo pump, I replumbed the whole trailer with PEX as I believe rubber to develop a rubber taste over time, especially with our desert heat.
Hope this helps and good luck with your water system.
FF
Old 04-18-2008, 09:00 AM   #11
1963 24' Tradewind
, , Minnesota
I bought a inca 33 gallon tank because my cylinder was missing probably a good thing. The only rubber hose I have is connected to the inlet to the inca tank. Should I junk the rubber and put pex in its place? I went with copper thru the whole trailer because I was told its the best to use if you want to drink the water. I had a 70 rolite that had all rubber and pvc lines and you didnt want to drink the water lol
Old 04-18-2008, 10:02 PM   #12
safari57's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
West Coast , BC
Send a message via MSN to safari57
Neat trailer embark.
I suspect a pressure washer will do a lot for removing your paint but stay away from rivets/seams.
Will be watching for photo updates as you get going on it. It is always fun to resurrect something that was wonderful in its day, then left to deteriorate until someone who really cares comes along and gives it a new life.
Barry
Barry & Donna
Life is short - so is the door on a '51 Flying Cloud (ouch)
safari57 is offline   Reply With Quote
Old 04-19-2008, 08:58 AM   #13
1962 24' Tradewind
Barry
Barry, you're onto our plan. Being in Oregon, we're real used to pressure washers (moss, you know). We just did a "test patch" and the paint washes away almost effortlessly. What's surprising is that the original protective coating covers almost 75% of the Trade Wind's surface, although it's faded and dull in that way we're all familiar with. Underneath the coating the metal is very ... um ... shiny. We have high hopes.
Pictures in a few days ...
tom and molly
Old 04-26-2008, 02:16 PM   #14
1962 24' Tradewind
Progress after 2 weeks:
1. The de-humidifier has sucked about 5 gallons of water out of the interior.
2. We've succeeded in mounting our two original Airstream propane bottles to the bottle stand. Now we're taking them to the propane guys (not quite as good as Hank Hill) to have the surgery done to make them compliant with the new standards.
3. the process of removing the makeshift interior cabinets has begun.
4. We've discovered that Airstream did not produce Owner's Manuals until 1964.
We have QUESTIONS!
First, we've looked on the WBCCI forums for some clues as to how to research the history of our 62's red numbers. Seems like they are all asleep on those particular forums. Perhaps WBCCI is too? Any advice as to how to find out more about ourTrade Wind's old red numbers would be appreciated.
Second, I - tom -am a dunce, because I can't seem to make the airforums search engine find me any info on how to acquire a blue Air # and be part of this. Someone please point us to this place.
Third, we're wondering about the appropriateness of continuing this thread here. Would it be more appropriate to move any further discussion of our progress on restoring the 62 Trade Wind to the Trade Wind forums? Should our pictures be uploaded to this thread, or would everyone prefer them uploaded to the Vintage Airstream photo galleries?
Thanks a bunch,
tom and molly
'61 Tradewind lee_jachter 1959-69 Tradewind 11 04-20-2010 01:47 AM
Wounded '61 Bambi Rescued in Texas! robbve Member Introductions 30 10-22-2009 09:37 AM
Best p/u TV for 71 Tradewind Lumatic Tow Vehicles 3 01-23-2008 08:16 PM
A/C for '72 Tradewind cameront120 Furnaces, Heaters, Fireplaces & Air Conditioning 6 06-07-2006 06:56 PM
'67 Tradewind, anybody? pinkflamingoes 1959-69 Tradewind 23 04-27-2004 11:47 AM
