Go Back   Airstream Forums > Airstream Community Forums > Our Community > Member Introductions
Old 08-23-2009, 09:56 PM   #1
whitley city , Kentucky
Rear sag question
My wife and I just found a 73 Overlander while driving around. It seems like a good price for the condition. I do have one concern though. Under the trailer at the back just in front of the bumper it is sagging on the bottom under the bathroom. How hard is this to repair?
Thanks, Bill
$bill is offline   Reply With Quote
Old 08-23-2009, 11:28 PM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 194
Rear sag question
Greetings Bill!
Welcome to the Forums!
Thanks, Bill
From your description, it could be one of several issues that could be relatively inexpensive to repair to others that could be exceptionally expensive and/or time consuming to repair.
  • If it is just the aluminum bellypan sheet sagging, it may need little more than a few replacement rivets.
  • It could be that the blackwater tank support braketry has rusted through and permitted the tank to drop pushing the bellypan down.
  • It is possible that the rear frame members have rusted to the point that they are in the process of failing allowing much of the rear structure to sag.
  • It is possible that the rear floor has rotted to the point that the bath fixtures are nearing the point where they may fall through the floor.
  • The combination frame extension/drag guard that the bumper attaches to may have welds that are failing or may have serious rust problems.
It is very difficult to predict which, if any of these issues might be causing the problem that you describe. You might want to see if one of the Forum Volunteer Inspectors is near you -- that may be the easiest way to determine if the problem is critical or something relatively minor.
Good luck with your investigation!
Kevin
Kevin D. Allen
WBCCI (Lifetime Member)/VAC #7864
AIR #827
1964 Overlander International
What causes rear sag on some airstreams? durans54 Repairing/Replacing Floor &/or Frame 4 12-02-2006 08:25 PM
Rear End Sag JimGolden Repairing/Replacing Floor &/or Frame 7 11-09-2005 09:20 AM
Rear Separation and Rear Sag on my '72 mello mike Axles 17 06-16-2005 01:58 PM
Rear end Sag? Fun-Lovin Repairing/Replacing Floor &/or Frame 2 10-27-2003 08:03 AM
Rear sag- or no rear sag? aviontt Repairing/Replacing Floor &/or Frame 14 08-27-2003 05:38 PM
