Old 02-05-2007, 03:33 PM   #1
1976 31' Sovereign
Oswego , Illinois
Racer Bill
I Have A 1976 Airstream Purchased New In 1976 {this My 6th & Last} Trailer. Airstream In 1976 Made Partitions Out Of Plywood And Put Vinyl Laminated On The Wood Much Like Contact Paper Over Time This Has Shrunk & Peeled Off. How Do You Get Contact Glue Off Wood Without Ruining Wood?. Any Ideas?. Thks Bill As Far As Cracks In End Caps I Replaced Nose Once Lasted About One Year Before Cracked Again Stop Drilled Both Cracks Still Continued To Crack
Old 02-05-2007, 03:44 PM   #2
1976 31' Sovereign
St Petersburg , Florida
Try paint stripper. It will not harm the wood, but do not allow to get on floor or other areas. I use "Dad's Easy Stripper". Make sure you follow instructions on can. My 76 Sov is doing the same thing in areas. I plan to pull paper off and paint. As far as the endcaps go, mine appear to be fine so I don't know what to say there.
Actually before I used paint stripper, you should try Laquer Thinner, or MEK. If either works, you'll notice immediately because the glue will gum-up. You can then take a plastic putty knife to scrape the gummey glue off without cutting into the wood.
Good luck,
Steve
DreamWeaver is offline   Reply With Quote
Old 02-05-2007, 03:50 PM   #3
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Welcome to the Forums.
I would first try mineral spirits and then naptha (lighter fluid) before moving on to laquer thinner. The mineral spirits and naptha are both glue disolvers and yet kind to the surface and surrounding areas.
SuEllyn & Brian McCabe
Bill WGG 7705 Member Introductions 2 10-25-2006 10:31 PM
Oh No, Mr. Bill. I Have a Fake Sovereign Alumaholic 1974 - 1979 Sovereign 14 07-21-2006 04:48 PM
Broken Exterior Door Lock fmzjwill Doors & Locks 37 03-28-2004 03:21 PM
A two dollar bill?? grin.. FrankR Off Topic Forum 4 04-21-2003 06:09 PM
Those Numbers JLD Our Community 5 02-21-2003 07:42 PM
