Old 09-10-2008, 12:58 PM   #1
2005 16' International CCD
2015 Interstate Coach
Bandon , Oregon
Quiksilver and 55 Ford
What a helpful bunch all of you are. It's good to see honest and straightforward answers to questions.
We own a Quiksilver and recently restored a 1955 Ford just for hauling it on trips. During the first test drive it tracked perfectly, but porpoised just a bit on road undulations. Do I have too much (or too little) weight on the hitch?
FYI, the car has air shocks, a 460 Lincoln engine with C6 transmission, Gear Vendor Over/Underdrive and a numerically low rear end ratio (about 1900 rpms at 65 mph).
I also have weight distribution hitch and have the chains set on the fourth link.
Any recommendations or suggestions would be greatly appreciated.
Art
Rapa Nui is offline   Reply With Quote
Old 09-10-2008, 02:03 PM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings Art!
I suspect that there may be two or three things conspiring together to produce your freeway hop/bobb.
  • Weight Rating of Weight Distribution Bars. I suspect that you need no more than 600 pound bars and possibly a bit lighter than that.
  • Air Pressure Maintained in Shocks/Springs. While it doesn't seem intuitive, carry only the minimum air pressure recommended by the manufacturer -- on my Eldorado that is 15 p.s.i. This adjustment is to allow the weight distribution hitch to do its work.
  • Potable Water Tank. If the water tank is front mounted, traveling with it full or near full can be helpful -- it makes a noticable difference with my Minuet.
Sometimes, some porpoising may be inevitable as a result of the spacing of road expansion joints -- there is one stretch of US 151 that will produce some freeway hop despite having the hitch/towing combination adjusted for optimum handling.
Good luck with your Bambi/Vintage Ford combination!
Kevin
Kevin D. Allen
AIR #827
overlander64 is online now   Reply With Quote
Old 09-10-2008, 06:14 PM   #3
Bandon , Oregon
Excellent advice. Thanks Kenvin. I'll play with the air shocks first and wend my way through your other suggestions.
Art
Old 09-16-2008, 11:00 AM   #4
jpeterman's Avatar
1972 27' Overlander
Graham , North Carolina
we do need some pictures of the 55 and the Quicksilver.
Take care
Jerry
"AIR 17559"
wear it out, don't rust it out
Jerry
jpeterman is offline   Reply With Quote
Old 09-18-2008, 01:45 PM   #5
Bandon , Oregon
Jerry. Thanks for asking.
Here's the rig after its first test run. Other photos, if interested, can be seen at www.photobucket.com The album is under cnwmr.
http://i118.photobucket.com/albums/o...verSurfer3.jpg
Old 09-18-2008, 01:52 PM   #6
willyd's Avatar
1993 34' Limited
Melbourne Florida , Springfield Ohio
Great looking - don't know which one I like best - Thanks for sharing. - Do you have any interior pictures?
willyd is offline   Reply With Quote
Old 09-18-2008, 03:13 PM   #7
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
I was just thinking that is SWEEEEEEEEEEET............
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 09-19-2008, 10:14 AM   #8
Bandon , Oregon
Just finished the interior and will have photos soon. Thanks for the kind words.
Art
Old 09-29-2008, 07:53 PM   #9
jpeterman's Avatar
1972 27' Overlander
Rapa, thats a great looking rig. I drove a 56 chev 2 door wagon from Santa Cruz Cal to Graham NC back in the day (72) you are in for a great adventure
Take care
Jerry
"AIR 17559"
Jerry
Old 09-29-2008, 10:31 PM   #10
Bandon , Oregon
Adventures are the plan. I remember 72. I was hired by a California publisher and moved from Detroit. Had a 1935 Reliable travel trailer, purchased from a neighbor for $100, which we painted black with a yellow top and giant yellow sun on the sides towed behind a new yellow Malibu. Too young and stupid to realize I was putting my family in jeopardy, but we made it and the Reliable lived up to its name.
Second point: Thanks to Kevin for the advice on the air shocks. After playing with the air pressure, got rid of the last remnants of porposing.
Art
16' Bambi Quiksilver Edition mbrawner Our Community 16 07-07-2016 08:51 PM
New Airstream owners - Bambi Quiksilver Scooter&Bear Member Introductions 5 04-30-2007 06:52 PM
does it bother any other quiksilver owners? quiksilver Member Introductions 6 01-20-2007 08:41 PM
2006 Quiksilver Edition Bambi 16' jbird Member Introductions 22 04-14-2006 09:18 AM
2005 Quiksilver Bettymsb Member Introductions 2 01-11-2006 10:28 AM
