Old 03-09-2015, 01:59 PM   #1
2015 Interstate Ext. Coach
Boise , Idaho
Power consumption for a refrigerator
We just purchased a 2015 Airstream Class B. We boondock a great deal so I will be using battery power a great deal. I am curious about how much power the refrigerator will consume. We do have a solar panel as well as the generator.
Dbones is offline   Reply With Quote
Old 03-09-2015, 02:33 PM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
My experience is this:
If you're running the fridge in 12v mode (inverter either off or in "charge only" mode) AND you've got a sunny day, the solar panel will keep up with the drain from the fridge. Running the fridge in 120v mode through the inverter, OR cloudy/rainy days that reduce the effectiveness of the panel, you'll lose about 5% to 10% charge per day. You'd be surprised at how much power the inverter/charger uses just to run itself.
I consider the stock solar panel as a means of keeping the house batteries charged in storage, not so much as a means of extending your boondocking duration. For boondocking you might want to consider upgrading to a larger solar panel and/or adding a second panel.
Don't be afraid to run your generator, though. You need to run the generator every so often to keep it in good working order anyway, so setting aside an hour to run the generator every couple of days does no harm except to your on-board propane supply. Besides, you need to start the generator while the house batteries still have enough power TO start the generator! Run the batteries down too far and the generator won't start.
Besides, in summer it may be more advantageous to park in the shade to keep the van from getting uncomfortably hot, in which case the rooftop solar panel can't help you.
Cats and ultraleather Airstream upholstery don't mix!
Old 03-09-2015, 03:13 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
If you are not plugged into shore power your frig will run on gas. The amount of electrical power, 12 volt, used in this mode is too small to measure or worry about.
Your usage of lights would have a far greater draw on the batteries than the frig
2004 Excursion 4x4
Old 03-09-2015, 03:17 PM   #4
The OP has a 2015 Airstream Interstate with a Nova Kool refrigerator. It does not run on propane, only on 12vDC or 120vAC.
Old 03-09-2015, 03:31 PM   #5
HowieE's Avatar
Images: 12
"NEVER MIND"
I do have to ask though. Why would they make such a thing?
2004 Excursion 4x4
Old 03-09-2015, 03:35 PM   #6
"NEVER MIND"
Dunno.
Old 03-09-2015, 03:42 PM   #7
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Howie,
For those who do not what to cut holes in the side or roof for venting, for those who can utilize the up to 30 degrees off level that the Danfoss compressor can run, for those who want to have the refrigerator running while traveling down the road without the propane on and probably several other reasons that I cannot think of right now.
Bill
"NEVER MIND"
Just my personal opinion
Old 03-09-2015, 06:06 PM   #8
HowieE's Avatar
Images: 12
Yes. Thinking back I do know someone that installed that type frig in there trailer. I just did not realize the name when I first read it and did not know they were offered in new units.
His claim was the operating wattage was extremely low, almost beyond belief.
Maybe someone will post the specs.
2004 Excursion 4x4
Old 03-09-2015, 08:17 PM   #9
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Howie,
I installed a 9 CF unit in our Liner. The claimed electric draw is 2.8 A.
Bill
Old 03-09-2015, 10:35 PM   #10
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
My 10.1 residential fridge draws about 8 amps 12V DC through the inverter. (When the compressor is running)
.Click image for larger version
Name:	ImageUploadedByAirstream Forums1425962099.880123.jpg
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
Power consumption of various 12 volt items guy99 Batteries, Univolts, Converters & Inverters 19 10-18-2008 06:07 PM
Consumption Estimates campadk Electrical - Systems, Generators, Batteries & Solar 8 02-03-2007 09:54 AM
Poll: FUEL CONSUMPTION brunoffrance On The Road... 32 02-29-2004 04:37 PM
LP consumption by the furnace? ipso_facto Furnaces, Heaters, Fireplaces & Air Conditioning 18 12-10-2003 10:43 AM
Fuel Consumption: (curious) Drew Tow Vehicles 15 12-26-2002 06:28 PM
