Old 09-24-2007, 10:37 PM   #1
Salt Lake City , Utah
"One amore time"
Have been reading plenty of good information but could use some specifics. I purchased a 1974 31' Airstream in good condition. It does need new carpet and come cleaning. I think I will replace the carpet with Pergo flooring and try to clean the material used on the wall paneling. what advice is out there on removing the windows to clean out the flaking coatings? Also is the blue trim strip that covers the rivets on the outside available?
Burke is offline   Reply With Quote
Old 09-25-2007, 01:49 AM   #2
juel's Avatar
1976 31' Sovereign
Chandler , Oklahoma
Images: 24
Well, I haven't had the nerve to remove the windows in mine, but I know many on here have. Oh yes, Welcome to our world! I think if you will contact your nearest Airstream dealer they can order that blue trim for you. I have an Argosy and I was able to order the orange vinyl inserts from Airstream. It's a lot cheaper if you get it from a dealer than from some other sources. I have just purchased a 1976, 31ft Sovereign, so I'm hoping you will be posting pictures of what you do. This silver thing is all new to me.
juel is offline   Reply With Quote
Old 09-25-2007, 05:20 AM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Welcome to the forums.
Yes, you can remove the windows to clean them, all it takes is a ratchet and socket(either 1/2" or 7/16"). Unlatch the window from inside, lift the window, unbolt the support arms from the window frame, and lift the lower part of the window way up past 90 degrees. The hinge will drop out of the lip holding it in place. You can then clean the windows, or the area inside the windows, and replace the screens. Installation is the reverse of removal, just make sure the hinge is all the way inserted into the lip before lowering the window.
The blue rubrail and beltline inserts are available from Airstream, or Inland RV.
first-time poster.....long-time reader ("lurker") happyfella Member Introductions 3 08-21-2006 08:55 PM
Airstream "Time Share"? Whats' next???? Jim Jarzabek Off Topic Forum 12 03-14-2006 11:56 AM
NEU 064 : New England Rally-"A Faire of a Good Time Rendezvous" AirHog WBCCI Rallies & Events 17 10-06-2004 11:14 AM
Airstream "sighting" TIME, April 7 issue Kistler Our Community 2 04-02-2003 07:23 AM
