Old 08-16-2007, 12:52 PM   #1
1974 29' Ambassador
Niskayuna , New York
Send a message via Yahoo to CBsquidSS
Nub here
We made the plunge and purchased '74 Ambassador - having a blast cleaning and fixin' it from years of non-use. Found some cool fixes from the PO – i.e. a battery charger wired into the Uni-Volt (it actually seems to work). Already re-sealed the Vista windows and am now looking at the axels. What is the “real” need time to replace them? I have seen that when they are at 0 degrees they should be replaced, and as mine are around there I am concerned. The trailer pulled fine and I can say the axels do have some spring left, but I certainly don’t want the thing to fall apart. I would like to put off the replacement as long as possible to concentrate on making it livable……thanks!!
[IMG]file:///C:/Documents%20and%20Settings/james.archer/My%20Documents/Jay/74%20Airstream/PICs-Ambasador/Redux/DSCF0908a.JPG[/IMG]
CBsquidSS is offline   Reply With Quote
Old 08-16-2007, 12:59 PM   #2
1974 29' Ambassador
Old 08-16-2007, 01:06 PM   #3
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Take a pic of the side view of the trailer and post it here. I'll let you know if you need new axles.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 08-16-2007, 01:17 PM   #4
1974 29' Ambassador
side view - '74 Ambassador
Old 08-16-2007, 01:21 PM   #5
1974 29' Ambassador
Raised
Old 08-16-2007, 01:22 PM   #6
1974 29' Ambassador
Lowered
Old 08-16-2007, 02:43 PM   #7
Alumatube's Avatar
1984 31' Airstream310
New Holland , Ohio
That actually looks pretty good to me, although I am nowhere near an expert! From what I understand, the wheel well will be lower down the tires and even over the top part of the wheels when the axle needs replacing (when the trailer is sitting on the ground, not lifted). Hopefully someone with more experience will chime in here in a bit.
And I would actually replace axles *before* I made it livable, if it needed them, or at least do the livable mods and then the axles before I took it anywhere. If the axles need replacing, they can beat the heck out of the inside of your trailer (rivets popping, cabinets/walls separating, etc.) due to the roughness of the ride.
Congrats on your new baby, and thanks for the pics! We love pictures here.
Susan
"Despite the cost of living, have you noticed how popular it remains?"
1984 310 Limited Motor Home "The Rockin' A"
Alumatube is offline   Reply With Quote
Old 08-17-2007, 09:48 AM   #8
1974 29' Ambassador
Thanks Susan - It didn't look bad to me when purchased, and it did pull well, but when you hear the rear half of the trailer can fall off, one gets worried. The wheel hubs are around level with the axle, which means there is some room for wheel travel,
regards, Jay
re-plumbed '67 Safari tod47d Plumbing - Systems & Fixtures 4 01-30-2006 11:04 AM
